April 19, 2026, 12:54:22 AM *
Pages: 1 ... 21 22 [23] 24 25
Author Topic: D72 British Bellytank  (Read 193507 times)
TerryFwit
« Reply #330 on: May 24, 2017, 03:47:15 PM »
Drew's the Ironmonger in Reading saved the day and now have all the fixings needed to finish
http://i.imgur.com/Ug8DROS.jpg
Started bolting parts on again.
Rear axle on lower body
http://i.imgur.com/N1Srt7K.jpg
Air intake lower body
http://i.imgur.com/UjKnQm2.jpg
Front axle lower body
http://i.imgur.com/Fj10L5j.jpg
Air vent on engine cover
http://i.imgur.com/aPnoxJU.jpg
Fuel flap re-fitted, kind of grown on me now so will not be changing.
http://i.imgur.com/JujtFFB.jpg
http://i.imgur.com/fld47pE.jpg
http://i.imgur.com/aeCuhpa.jpg
Also put a piece of rubber around live terminal of battery so that it will not short out if it comes loose
http://i.imgur.com/xXzX0Sg.jpg
http://i.imgur.com/y8pqa4D.jpg
And another bit by the starter motor terminals (not tight)
http://i.imgur.com/zrP2VKL.jpg
This evening I need to modify the headrest as too restrictive to air flow into the carb intake.
http://i.imgur.com/6Ru9qmm.jpg
http://i.imgur.com/hvdWPpu.jpg
And put the firewall in
http://i.imgur.com/j9atB3E.jpg
« Reply #331 on: May 24, 2017, 06:15:02 PM »
Looks bloomin' brilliant!
TerryFwit
« Reply #332 on: May 24, 2017, 10:26:17 PM »
Tonight we had an epic battle with the firewall, not so easy with the engine and body on now. First part took ages working out the where to put the fixings and then finding out you can't get a drill in there now.
First bit
http://i.imgur.com/5Kkn8FE.jpg
Sussed it for the second bit
http://i.imgur.com/n7zB2lN.jpg
And the last bit, also reduced the size of the headrest
http://i.imgur.com/6VvdgNx.jpg
http://i.imgur.com/mDH1EpD.jpg
Still more to do but, that's for tomorrow.
« Reply #333 on: May 24, 2017, 10:37:33 PM »
Lovely.
TerryFwit
« Reply #334 on: May 26, 2017, 12:59:34 AM »
Well that was a long day, finished at half past midnight tonight. Lots of little jobs but took so long.
Accelerator springs re-fitted on carb and everything else checked.
http://i.imgur.com/copN14q.jpg
System filled up and bled easily through these 2 bleed nipples we fitted to each of the water ways after the weekends test run.
http://i.imgur.com/LuQn1My.jpg
Fan fitted to rad with horrible little fixings supplied(may make a shroud later)
http://i.imgur.com/OIfTiO1.jpg
New oil pressure gauge fitted, changed from electric to capillary.
http://i.imgur.com/KZtN1vg.jpg
Made the air intake to the carb, not finished in this picture.
http://i.imgur.com/kf2IjCf.jpg
Cleaned the blue protective cover off the tyre's.
http://i.imgur.com/thTn6Gc.jpg
And spent the rest of the day setting up the front end, balancing the wheels and doing the tracking.
Then put the stickers on
 http://i.imgur.com/UKvZpEo.jpg
And done !....... but you will have to wait to see....... Grin
« Last Edit: May 26, 2017, 01:02:33 AM by TerryFwit » Logged
« Reply #335 on: May 26, 2017, 05:06:12 AM »
Such a cool looking machine.
TerryFwit
« Reply #336 on: May 26, 2017, 10:13:10 AM »
Loaded on the truck last night, notice the time on the clock in the back ground ? Long day but worth cannot thank Nick, Chris, Gareth and Jon enough for yesterday.
Bound for Shakey. Grin
http://i.imgur.com/1cGXaR7.jpg
« Reply #337 on: May 26, 2017, 03:00:48 PM »
Outstanding work buddy!!
« Reply #338 on: May 26, 2017, 06:46:21 PM »
Fantastic! Good luck at the track! Smiley
« Reply #339 on: May 27, 2017, 07:16:34 PM »
http://i257.photobucket.com/albums/hh231/archie837/D055ECEF-1CC2-41D6-911A-7E05ABC17497.jpg
« Reply #340 on: May 27, 2017, 07:20:29 PM »
what did it go like ??
« Reply #341 on: May 27, 2017, 09:26:48 PM »
First run at 87mph.
Such a cool looking thing.
TerryFwit
« Reply #342 on: May 29, 2017, 03:56:57 PM »
Best time's so far 12.95s @104.6mph / 13.10 @ 106.7. Grin
« Reply #343 on: May 29, 2017, 05:49:31 PM »
Fantastic!
« Reply #344 on: May 29, 2017, 09:05:20 PM »
