April 19, 2026, 01:32:31 PM *
Pages: 1 ... 7 8 [9] 10 11 ... 25
Author Topic: D72 British Bellytank  (Read 193868 times)
TerryFwit
« Reply #120 on: December 06, 2016, 07:48:12 PM »
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cockpit/DSCF1642_zpsdhkhpvfw.jpg
Made a dashboard, very rough and simple at moment may change to wood with  a couple of slight curves below for knees. All the basic items here apart from 1 more toggle switch required. May not use the voltmeter as I only fitted it because it came in the set.
TerryFwit
« Reply #121 on: December 06, 2016, 07:49:34 PM »
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cockpit/DSCF1634_zpssp5h3ny6.jpg
TerryFwit
« Reply #122 on: December 06, 2016, 07:53:52 PM »
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cockpit/DSCF1649_zpso1kc6p4m.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cockpit/DSCF1650_zpsxnykq14w.jpg
As you can see space is tight so not many options for positions. They have to go there. May re-think the Kill switch as a bit too close to the frame.
TerryFwit
« Reply #123 on: December 06, 2016, 07:59:01 PM »
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cockpit/DSCF1653_zpslbnkhome.jpg
All starting to get very snug up at the front here, running out of room.
« Reply #124 on: December 06, 2016, 08:24:53 PM »
Looks great.
I assume the red button's the Start & the Kill switch is obviously Stop -so what does the black button do?
TerryFwit
« Reply #125 on: December 06, 2016, 09:33:00 PM »
Thank you. The black button is a green indicator lamp to show gearbox is in park via the start inhibit relay. Only 3 switched items on the car ignition, fuel pump and fan. Using a mechanical waterpump on this car so no switch needed unlike on the Trabant. Apart from the 2 kill switches, 1 in cockpit and 1 external at the rear that's about it. Maybe another for a rear light but apparently that is only required for Santa Pod.
« Reply #126 on: December 07, 2016, 10:18:36 AM »
Inhibitor -very sensible. Seen a few incidents where they weren't fitted or didn't work, (had a scary moment with my own Pop once too, when it dropped into gear while on tickover & trundled off backwards on it's own. Only the quick reactions of a mate stopped it ploughing through a neighbour's fence).
So what class will you be racing in?
TerryFwit
« Reply #127 on: December 07, 2016, 08:40:51 PM »
RWYB and just hope it makes it to the end of the track in one piece  Grin
« Reply #128 on: December 07, 2016, 09:04:07 PM »
 Smiley Will you be out in 2017? I'm not a massive drag racing fan, but always do the Hotrod Drags & Nostalgia Nationals at Shakey because they're "oldie" themed.
TerryFwit
« Reply #129 on: December 08, 2016, 04:36:32 PM »
That is the plan, hopefully done for Gary,s Picnic in May at Shakey.
« Reply #130 on: December 08, 2016, 05:03:39 PM »
Great -I'll try & get along.
TerryFwit
« Reply #131 on: December 10, 2016, 05:33:50 PM »
Make sure you have alternative plans as we have missed many deadlines. Grin
So in the back ground of the last few photos was the seat, or as it is now known 'The wingback bomber seat'.
It all started with a very excited Mr Conner as he could finally now start building his rocket ship.  Cheesy
(stole that comment from someone else)
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20seat/IMG_67792_zpstjwuc2hw.jpg
And came up with this. Also here is the first steering wheel cross brace and Gareths first ever attempt at a butterfly wheel made in his youth. Both of which are long gone
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20seat/IMG_67862_zpsnvmycxxi.jpg
TerryFwit
« Reply #132 on: December 10, 2016, 05:38:33 PM »
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20seat/IMG_0011_zps41xmamu0.jpg
Made out of 2mm ali and held together with 4mm  nuts and bolts. Eventually we hope to cold rivet together.
TerryFwit
« Reply #133 on: December 10, 2016, 05:40:03 PM »
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20seat/IMG_0013_zpssg8xmfhv.jpg
TerryFwit
« Reply #134 on: December 10, 2016, 05:44:45 PM »
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20seat/IMG_0033_zpsgn7mmiqo.jpg
Once we had the seat in and a couple of bits of wood to simulate the cushion it became evident the steering wheel angle felt wrong.
