April 19, 2026, 12:01:05 PM *
Pages: 1 ... 9 10 [11] 12 13 ... 25
Author Topic: D72 British Bellytank  (Read 193838 times)
TerryFwit
« Reply #150 on: December 17, 2016, 07:26:28 PM »
So working backwards, the radiator. Cant remember what car its for we just went round to the local parts place and asked to look at all the rads out the back and chose this one as it had the most suitable inlet/outlets and no other connections. £33.
Using the original mounting points made up a front and rear brackets.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20rad/DSCF1960_zpsrnwlhqj5.jpg
Front bracket.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20rad/DSCF1959_zpswftnftkc.jpg
Rear bracket.
« Last Edit: December 17, 2016, 07:29:24 PM by TerryFwit » Logged
TerryFwit
« Reply #151 on: December 17, 2016, 07:33:11 PM »
The brackets will sit on top of the rear chassis tubes and be held down with jubilee clips.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20rad/DSCF1958_zpsue9lyfuq.jpg
Front bracket.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20rad/DSCF1956_zpsac2ciaez.jpg
Rear bracket.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20rad/DSCF1957_zpstrnfxhvn.jpg
TerryFwit
« Reply #152 on: December 17, 2016, 07:41:09 PM »
Front rad mount, will be putting rubber bushes between the rad and the bracket holes.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20rad/IMG_6679_zpspvevj1ti.jpg
And the rear one in place. Just have to figure out how to plumb it up, but at lest we know where we are aiming for. And the battery.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20rad/IMG_66802_zpsgtmh3vwo.jpg
« Reply #153 on: December 17, 2016, 07:44:39 PM »
We used to hold blown hemi engines in my mates funny car with the same thing? Tubing held by jubilee clips? Grin
TerryFwit
« Reply #154 on: December 17, 2016, 07:55:02 PM »
First saw that type of fixing on slingshot dragsters at the track, could not believe you were allowed to hold your engine in like that.
Then looking at all the other cars and builds realised what is and isn't needed to make a car. Apparently you can use what ever you want to build a vehicle from as long as the safety cage is sound and the car can pass tech. Was originally going to use a massive piece of carved hardwood for the front rad bracket. Grin
TerryFwit
« Reply #155 on: December 17, 2016, 08:02:56 PM »
Battery mounted in the most simple way possible, bits of angle and some 10mm studding.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20battery/DSCF1929_zpstdmgkylz.jpg
Clamp for top made out of flatbar.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20battery/DSCF1931_zpsfihqa8fh.jpg
And done.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20battery/IMG_66772_zpsyzqtib2d.jpg
Next the fuel tank, a prime example of what was to hand...
TerryFwit
« Reply #156 on: December 19, 2016, 05:40:10 PM »
And this is what we are using as a fuel tank. A pressure tank from a central heating system, Will probably hold about a couple of gallons so plenty for what we need. Will coat the inside with something (any ideas?) and the shove a piece of fuel tank foam inside to stop fuel sloshing around.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20tank/DSCF1934_zps5zvd9ixg.jpg
TerryFwit
« Reply #157 on: December 19, 2016, 05:50:56 PM »
Purchased a fuel tank cap and neck from Car Builder Solutions and made a plate to go on to tank.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20tank/DSCF1936_zpsadd8g5bj.jpg
Welded in a fuel outlet on the bottom as well. Tank is steel and neck is ali.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20tank/DSCF1912_zpshejkbrcd.jpg
And done. Still need to put a breather pipe on the top and make a gasket for the Filler neck.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20tank/DSCF1937_zpsmjkg1sqd.jpg
« Reply #158 on: December 19, 2016, 05:58:01 PM »
That's unusual. I like it. Where will it go? Even with RWYB, the scrutineers won't allow fuel tanks directly above hot exhausts etc will they?
TerryFwit
« Reply #159 on: December 19, 2016, 06:02:00 PM »
And the right way up.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20tank/DSCF1938_zpswpx9iysr.jpg
And fitted in the only space left. Made a bracket across the rear of the top rails and welded a couple of mounting studs on so we could use the tanks own mounting plate.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20tank/IMG_6724_zps3c6omyks.jpg
« Last Edit: December 20, 2016, 07:17:43 AM by TerryFwit » Logged
TerryFwit
« Reply #160 on: December 19, 2016, 06:09:50 PM »
Started thinking about the tank and 10/12 kilos of fuel and the way the tank mount was tack welded to the side, we modified the mount so tank is held by the neck as well.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20tank/DSCF1939_zpsdxifs1yo.jpg
Looks a bit more secure like that.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20tank/DSCF1940_zps8xure59m.jpg
TerryFwit
« Reply #161 on: December 19, 2016, 06:25:04 PM »
And the 3 of them together. The radiator was easy as plenty of room in the middle, the rear not so much. The battery is as far back as possible, infact we need to trim off the excess from the top of the mounting studs and the ends of the top plate as they are almost rubbing on the inside of the body and the tank, well the height of that was decided by its own mount and the cross brace. We (hopefully) made the neck to the correct height that it will sit just below a small flap at the rear of the body.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20tank/IMG_67252_zpstwuv0hfv.jpg
TerryFwit
« Reply #162 on: December 19, 2016, 06:34:56 PM »
Hot exhausts?...think zoomie's!  Grin
« Reply #163 on: December 19, 2016, 08:39:56 PM »
Aah!
TerryFwit
« Reply #164 on: December 26, 2016, 10:42:47 PM »
Last 3 items that need mounts are the coil, the fuel pump and the expansion tank. The coil is fitted  on the top of the nearside chassis tube just behind the fire wall.
 http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF1926_zpsynh4suhq.jpg
And the fuel pump is on the offside lower tube just below the fuel tank. Wanted to use a Holley pump but too expensive at the moment.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF1910_zpsqczoydlb.jpg
« Last Edit: December 26, 2016, 10:58:34 PM by TerryFwit » Logged
