October 26, 2025, 10:43:11 AM *
Pages: 1 2 [3] 4 5 6
Author Topic: THE BLACK PIG,  (Read 33887 times)
« Reply #30 on: October 12, 2016, 02:49:59 PM »
You going single seater Mike?
« Reply #31 on: October 13, 2016, 06:01:03 PM »
yep,, but no seat for it  yet  Roll Eyes Roll Eyes
« Reply #32 on: October 18, 2016, 02:42:01 PM »
loads of bits  ordered  Wink Wink  but still no seat ==  budget  blown Roll Eyes Roll Eyes
« Reply #33 on: October 18, 2016, 06:40:36 PM »
 Cheesy
« Reply #34 on: October 19, 2016, 01:19:14 AM »
upto now
replaced
points + baseplate
advance mechanism
plugs
chain +sprockets
rear brake assembly
footpegs
rear wheel
rear tyre
brake rod and cross shaft
rear shocks
fuel lines ( upto test tank)
battery
ign wiring
oil +filters
attension to carbs +replaced missing screws
cleaned out carbs (twice)
handle bars
repaired and replaced variuos  studs n, nuts
reset valve clearance
adjusted cam chain
parts on order
new coils
new condensors
ht leads
plug caps
carb kits
clutch lever
brake master cyl +lever
fork seals
fork slugs
lamp brackets
air filters
horn
clutch rod seal
starter gears
tank is in the process of being cleaned
starter is here and will be fitted when gears arrive
exhuasts Huh?  fooked  but on going  thought process
new battery box needs to be designed and made
rear mudguard is in ,mock up, stage
need a front one
clocks need getting.
front tyre needs renewing  old is cracked
front caliper is overhauled ready to refit.
and the list go,s on and on
so i havn,t been idle   as i,m doing this ,, the trike,, a willys, jeep , a bedford QL is waiting in the wings  and i,m keeping the  8 leg foden on the road aswell as assisting the lads in the yard  with anything and everything including chainsaws and log splitters for there side line   job
PLUS
working on improving my  daily  a fully kitted out landrover 110
« Last Edit: October 19, 2016, 01:24:01 AM by spanners » Logged
« Reply #35 on: October 19, 2016, 07:34:20 AM »
There's keeping busy mate,but don't blow a fuse ? Kiss
« Reply #36 on: October 19, 2016, 10:40:02 AM »
You've been busy mate. Achieved a lot more than a lot of us, so don't beat yourself up about it.
« Reply #37 on: October 19, 2016, 09:04:12 PM »
just got home ,,brew food,, tin-ter-net,, then bed
about another 7 hours on the pig , two steps forward ,,, three steps back ,,
think i,m going to need another complete alternator / generator , rectifier  reg  set up  , its all a fookin mess and none of the wire colours match up to any diagrams that i can find  and a host of chopped up sh1te under miles of insult tape  Huh Huh
« Reply #38 on: October 19, 2016, 09:35:41 PM »
Yeah, that sounds like most old Jap bikes.
« Reply #39 on: October 19, 2016, 10:55:03 PM »
but what fits it   Roll Eyes Roll Eyes  its on a Q plate  frame  number according to ,,yambits,, == 1981 xs650 se
« Reply #40 on: October 20, 2016, 08:23:33 AM »
Suggest you have a think about going down the Permanent Magnet Alternator route.
Its an upgrade using more reliable, and potentially more easily available, components.
http://www.xs650.com/threads/how-to-permanent-magnet-alternator-swap-also-known-as-the-banshee-swap.5536/
http://www.smedspeed.co.uk/pmakit.html
http://xs650temp.proboards.com/thread/11096
« Reply #41 on: October 20, 2016, 03:48:51 PM »
Ha, you're lucky if they are different colours and you can trace them - when my little yammy was stolen and dumped, the buggers cut right through the wiring loom at the front - when a mate came to sort it out, every wire was brown!  Took him hours of trial and error and some odd results!
« Reply #42 on: October 20, 2016, 09:17:33 PM »
cheers mate i,v been thinkin alot about PMA  i,v heard alot of good stuff  but  not shure of costs
got new coils here and condensors on there way , new batt here  etc,,etc
give me an old truck and i can build the full electrical system  blindfold,,, but bikes   Roll Eyes Roll Eyes
« Reply #43 on: October 20, 2016, 09:31:14 PM »
can any body on here supply me with all the bits to do the above  please
Sid_Vicious
« Reply #44 on: October 20, 2016, 11:08:40 PM »
On this site there is dimensions and how to make the adapter plate if you go down that route. Probably some other good info too
