October 15, 2025, 10:37:31 PM *
Pages: 1 2 [3] 4
Author Topic: Reliant "B" Axle info  (Read 73501 times)
« Reply #30 on: December 17, 2011, 09:03:45 PM »
As promised i have added the outer drive shaft Bearings to the list.
These are the ones that usually get changed after the half shafts get pulled.
mukit
« Reply #31 on: January 03, 2013, 03:24:55 PM »
I'm presuming then that the "A" axle wheel bearing is  57mm ?
Edgytaff
« Reply #32 on: October 29, 2015, 07:15:10 PM »
Hi need help with a trike made from a gt 750 kawasaki prop shaft not turning properly has any one done one please
« Reply #33 on: October 29, 2015, 07:36:42 PM »
I done a kz550. what wrong with the prop?
« Reply #34 on: October 29, 2015, 08:10:12 PM »
A bit vague. Some more info and folk on here might be able to help.
« Reply #35 on: October 29, 2015, 08:17:49 PM »
Did you fit the axle upside down Edgytaff?   If not, it'll be trying to go backwards.
Edgytaff
« Reply #36 on: October 29, 2015, 09:04:08 PM »
Hi everyone thanks for the replies it's not lining up as if the prop is going over to far to the middle of the diff and not turning?  would I have to cut the axle to get the diff off centre or is it the prop has,nt got enough angle on it?  I'm a welder so not sure about it thanks
« Reply #37 on: October 29, 2015, 09:19:21 PM »
Propshafts are usually designed to run offset,
That's what UJs are for.
Where abouts in the world are you.
« Reply #38 on: October 29, 2015, 09:41:36 PM »
There is a limit as to how far a UJ will work correctly. Also UJ's should be used in pairs and must be aligned to get the phasing right.
Bikes like the GT750 usualy have a CV joint at the gearbox end so if used with a UJ at the axle end the offset should be minimal. Shortening one side of the axle will help.
« Last Edit: October 29, 2015, 10:03:40 PM by Olds » Logged
« Reply #39 on: October 29, 2015, 09:58:14 PM »
For us to help can you post a photo of it so we can see the prop shaft angle
« Reply #40 on: October 29, 2015, 10:11:42 PM »
Looking at a 750 drive shaft it seems to have a hookes joint or UJ so it may be as simple realigning the two joints. All the same if the prop is short then reducing the angle is a good idea.
Edgytaff
« Reply #41 on: October 29, 2015, 10:30:03 PM »
I'm in south Wales iv tried a few things think that shorting the axle on 1 side to fetch the diff over so prop in straighter?  That's only thing I can think of now but swing arm all done and have to make new one to move diff in line now?
« Reply #42 on: October 29, 2015, 10:43:56 PM »
Edgytaff
I thought you were me to,Rhondda born Rhondda bred.
Do you have a sliding propshaft,Telescopic like.
Edgytaff
« Reply #43 on: October 30, 2015, 09:13:10 AM »
Hi hunter I'm from Rhondda living in Maesteg now tho no its the shaft off the bike been cut down and a sleeve over with a quad uj, it seems to be the bikes uj is not enough movement to get to the diff on axle?
« Reply #44 on: October 30, 2015, 10:55:38 AM »
You should never have left, i could have popped over Penrys hill and had a look Grin, would have taken ten mins to get there not to say i won't come to Maesteg,Anyway i think it would be best if you started a thread of your own,As this has tagged onto the back of an old thread,Try and get some photos up so that we can have a good look with what's going on.
Pages: 1 2 [3] 4
