June 03, 2026, 02:02:19 PM *
Pages: 1 [2] 3 4
Author Topic: Reliant "B" Axle info  (Read 98170 times)
« Reply #15 on: November 25, 2011, 06:26:26 PM »
No problem. Im a very patient man but Ive just bit the egde of my desk off Wink Cheesy Cheesy
Seriously though, its good that we can help each other Smiley
« Reply #16 on: November 25, 2011, 06:48:31 PM »
Hi Pete. can you just run that past me again. Grin
« Reply #17 on: November 25, 2011, 06:53:58 PM »
First I ........... aagghhhhhhhhh I need whiskey Cheesy Cheesy Cheesy
« Reply #18 on: November 25, 2011, 07:00:13 PM »
 Grin Grin Grin
That's funny
« Reply #19 on: November 25, 2011, 08:15:28 PM »
Sorry I`m late, only just got here...............what were we talking about?HuhHuhHuhHuhHuhHuhHuh  Grin Grin Grin Grin
« Reply #20 on: November 25, 2011, 08:23:03 PM »
Go and get your coat Grin Grin
this is done and dusted Smiley
Al
« Reply #21 on: December 11, 2011, 08:44:56 PM »
is this the same BEARING 6305 2RS 25MM X 62MM X 17MM 63052RS
http://www.ebay.co.uk/itm/BEARING-6305-2RS-25MM-X-62MM-X-17MM-63052RS-/200499490481?pt=LH_DefaultDomain_3&hash=item2eaeb36eb1
need a set for a b axle so have ordered the bearings o fthis company for the a type with no problems jsut wasnt sure if they were the same
« Reply #22 on: December 11, 2011, 09:39:12 PM »
Hi Al.
Yes, this is the Outer Halfshaft Bearing for the "B" axle, (2RS = 2 rubber seals, so its sealed both sides to keep dirt out and oil in)
I would be interested to know the part number/sizes for the similar bearing on the "A" axle, so we can start making another parts/suppliers/price list.
Cheers
 Smiley
Al
« Reply #23 on: December 11, 2011, 11:45:55 PM »
hi pete
thanks the ones i use for the a type axle are for the half shaft or wheel bearings
http://www.ebay.co.uk/itm/BEARING-LJ1-OPEN-RLS8-LS10-1-X-2-1-4-X-5-8-LJ1-/200480527249?pt=LH_DefaultDomain_3&hash=item2ead921391
for the pinnion bearings im sure iv got it wrote down somewhere i will try and get as well as the details on the seals
Al
« Reply #24 on: December 11, 2011, 11:55:38 PM »
t bone was kind enough to give me this for the a type axle
You could in a bit of trouble her mate, there are 2 different half shaft seal sizes because at some point Reliant went from imperial to metric, they also did this with the wheel bearings so if you can I.D the bearings you should know which you have.
Anyway the half-shaft seals are: GACO.IND. 49516; 51x39x6 mm. or 2.0x1.5x0.25 imp.(nom.dims.), and the Pinion seal is a GACO.IND. 49517
« Reply #25 on: December 12, 2011, 07:11:55 PM »
hi pete
Al. I think you'll find that the above bearing is "open" and not sealed, therefore I doubt it would be suitable for using as the outer halfshaft / wheel bearing.
Al
« Reply #26 on: December 12, 2011, 10:27:23 PM »
SORRY PETE IT IS THE RLS8 RUBBER SEALED
RUBBER http://www.ebay.co.uk/itm/LJ1-RLS8-2RS-RUBBER-SHIELDED-IMPERIAL-BALL-BEARING-/320316850843?pt=LH_DefaultDomain_3&hash=item4a945f429b
HAD TWO IN WATCHING
« Reply #27 on: December 13, 2011, 09:27:13 PM »
Ahha, thats better, it make sense now Smiley
« Reply #28 on: December 16, 2011, 11:38:11 PM »
Regarding the 'A' axle
If any body is interested i have just bought all the bearings for the diff from Reliant Partsworld.
Product code               Description                                       Quantity     unit price     line value       VAT
25955                 oil seal 49517 diff pinion                                     1          9.99          9.99              1
20195                   bearing taper                                                    2          12.02        24.04             1
200209                 bearing taper/1988-1922 pinion head                    1          8.44           8.44             1
6411                   bearing F/Hub inner                                            1          4.68           4.68             1
The outer drive shaft bearings are skf 8-RS1
They came as a wheel bearing and oil seal kit - They are made by Premiere Vehicle Bearing Components
The Code for the Bearing kit is BRT959  Cost per side 14 Pound. I bought these of ebay.
Hope this helps somebody
« Last Edit: December 18, 2011, 11:44:22 AM by merv » Logged
« Reply #29 on: December 17, 2011, 03:19:48 AM »
bash that onto a new thread for a sticky i'd say!
Pages: 1 [2] 3 4
