April 29, 2026, 06:44:51 PM *
Pages: 1 ... 35 36 [37] 38 39 ... 70
Author Topic: hillman superminx 1962  (Read 391867 times)
« Reply #540 on: August 10, 2012, 09:34:51 PM »
I`m sorry but the parameters of this thread seem to have been paramounted  Grin Grin Grin Grin
« Reply #541 on: August 11, 2012, 07:56:10 AM »
looks like we are'nt going to meet the nasc nats deadline.
« Reply #542 on: August 11, 2012, 04:13:08 PM »
That's a shame mate. I've stopped giving myself deadlines now. Mine'll be ready when it's ready.
Keep plugging away Chris.
« Reply #543 on: August 11, 2012, 04:29:57 PM »
had a nice day at pats, rear brake lines fitted, handbrake sorted, stripped most of the trim off. left pat with a modern metal art sculpture pretending to be a mastercylinder/servo mount!!!
also posted this on our club site!!!
not going to make it to the nats ( unless a gang of us get stuck in!!!  nudge nudge wink wink   )
« Reply #544 on: August 11, 2012, 06:22:33 PM »
 Cheesy
« Reply #545 on: August 11, 2012, 06:43:40 PM »
[/quote]
Post things like that to our club you end up with 30 or 40 drunken bums as house guests for a weekend and still get nothing done. Your club is obviously more civilised than mine  Grin Grin Grin Grin
« Reply #546 on: August 14, 2012, 10:53:15 PM »
got some electrical bits, switches, relay (for cooling fan) also got a speedo cable on the way to butcher!!!  Shocked
« Reply #547 on: August 31, 2012, 01:54:15 PM »
been told it will be primer ready in about a week Grin Grin Grin
going to try an get most mechanical stuff done tomorrow, which could also include a start up!!!!! Shocked Shocked
i must take some pics!!
kevsky
« Reply #548 on: August 31, 2012, 03:46:32 PM »
yes you must
« Reply #549 on: August 31, 2012, 03:56:07 PM »
And a video for YouTube!
That's great news Chris. Wish mine was progressing that fast!
« Reply #550 on: August 31, 2012, 05:46:29 PM »
not seen it for over three weeks!!!!
« Reply #551 on: August 31, 2012, 08:29:33 PM »
So you haven't seen it since he painted it pink then?
« Reply #552 on: September 01, 2012, 06:07:28 PM »
update time.
as you can see pat is cracking on with the paint, having to remove all the grey & redoxide that some prat brushed on!!!  :unsure:
todays progress was brakes all plumbed in(need longer front flexis though) clutch cable fitted, steering shaft fitted. does'nt sound a lot but nothing went to plan or as straight forward as it should of been. got a list of stuff to get, but jobs list is(hopefully) getting shorter.
big thanks to pat and jenny again. x.
most of trim removed, o/s headlight needs rivets drilling out.
this shows how much work pat is putting into body work, rear lights will be removed once wet sanding above them has finished.
white roof again!!!
door handles will be removed, but we've chickened out on taking windows out!!!
lots of work involved with fitting servo/master cyl. all done by pat. this and clutch(converted to cable) all work of standard pedal box.
corsa 70amp alternator fitted, all custom brackets.
here you can just see the new sliding steering shaft, connected to a steering rack, and yes it all works correct!!! that was a big moment this afternoon when the wheels turned the correct way!!!
not a show winning build, but done to a hell of a tight budget.
will update as things progress.
« Reply #553 on: September 01, 2012, 08:42:00 PM »
Looks great Chris.  Grin
« Reply #554 on: September 01, 2012, 09:24:15 PM »
thanks andy, the outside looks worse than ever!!!!
also had a bit of a hiccup with painting it as it might have to go elsewhere!!!!!
