April 29, 2026, 06:29:54 PM *
Pages: 1 ... 34 35 [36] 37 38 ... 70
Author Topic: hillman superminx 1962  (Read 391854 times)
« Reply #525 on: August 05, 2012, 10:35:28 AM »
pat is finishing servo/b/cylinder mountings during week. that leaves me steering to re-assemble, clutch cable to refit, fit all new brake lines, bleed etc. finish/tidy wiring, refill g/box an axle with oil. fit airfilter(new carb base to make) cut hole in bonnet(if not enough clearence) fit radiator, pipe work etc. check for leaks then get her running!!!!
so not much!!!, realy need to get that lot done by next week end!!! as got to get mot, and a shake down run if possible to our show at a local air museum on the 19th august!!!!
« Reply #526 on: August 05, 2012, 11:37:03 AM »
You crazy gasser guy you!
Good luck mate!  Shocked
« Reply #527 on: August 05, 2012, 07:00:23 PM »
crazy yes!!!
« Reply #528 on: August 06, 2012, 07:13:50 PM »
i've written a quick list of things to do!!!
brake servo/master cylinder.
brake lines.
prop centre mount.
refit clutch cable.
adjust handbrake cable.
bleed brakes.
fit alternator.
finish wiring.
fit new airfilter & base.
fit gear stick/g/box surround.
alter speedo cable.
gearbox/axle oil.
fit radiator + pipe work.
new wiper blades.
rad cooling fan.
start up check leaks etc.
and breath!!!!!!
« Reply #529 on: August 06, 2012, 08:18:13 PM »
« Reply #530 on: August 08, 2012, 10:36:33 PM »
brake lines.
prop centre mount.
refit clutch cable.
bleed brakes.
fit alternator
finish wiring.
alter speedo cable.
gearbox/axle oil.
new wiper blades.
rad cooling fan.
set caster angle.
« Last Edit: August 09, 2012, 05:10:48 PM by poprodder » Logged
« Reply #531 on: August 08, 2012, 10:46:13 PM »
Build a time machine.
« Reply #532 on: August 08, 2012, 10:48:50 PM »
« Reply #533 on: August 09, 2012, 07:58:55 PM »
If only
« Reply #534 on: August 09, 2012, 10:08:24 PM »
I built a time machine a week next Wednesday.
« Reply #535 on: August 10, 2012, 06:29:45 AM »
but i nicked it and destroyed it before you could tell you past self about it
« Reply #536 on: August 10, 2012, 07:29:20 PM »
Damn you & your time parallex!
« Reply #537 on: August 10, 2012, 07:31:01 PM »
parallex!?!
« Reply #538 on: August 10, 2012, 09:20:43 PM »
I thought it was a Paralax.....................or was it a pardigm?...........................paraglider?..................................................(mutters and mumbles, leaves stage right)
« Reply #539 on: August 10, 2012, 09:23:04 PM »
I'll see your paraglider and raise you a paradiddle!
