April 30, 2026, 10:40:52 AM *
Author Topic: Reliant engine service items part numbers  (Read 24915 times)
« on: November 07, 2009, 07:13:32 AM »
Hopefully these may be of some help to someone. All correct as far as i`m aware but as always please check before fitting.
Oil Filter
 Fram   PH2834
 Unipart  GFE107
 Champion C103
Air Filter
 Fram       CA5634
 Unipart    GFE2361
Spark Plugs- pre 1996
 NGK           BPR5ES
 Champion    RN12YC
 Bosch         WR8D
Spark Plugs - post 1996
 NGK        BCPR5ES
 BOSCH    F8DCOR
Contact Set Pre 1981
 Bosch          1 237 013 834
 Commercial Ignition  CS132
 Intermotor    22580
 Lucas          DSB 108
 Motaquip     VCS108
 Unipart        GCS2118
Contact set post 1981
 Commercial Ignition     CS179
 Lucas                       DSB191
 Motorcraft                 EDP109
Condenser
 Bosch          1 237 330 827
 Commercial Ignition   CON85
 Intermotor    33720E
 Lucas          DCB104
 Motaquip      VCD111
 Motorcraft    EDC151
 Unipart        GSC2109
Distributor Cap
 Bosch        1 235 522 843
 Commercial Ignition   XD79
 Intermotor  44750
 Lucas         DDB108
 Motaquip    VDC108
 Motorcraft  EDH90
 Unipart       GDC136
Rotor Arm
 Bosch        1 234 332 848
 Commercial Ignition  R79
 Intermotor  47540
 Lucas         DRB104
 Motaquip    VRA110
 Motorcraft   EDR63
Ignition Coil (non ballast resistor)
 Bosch                     0 221 102 003
 Commercial Ignition   IC8029
 Intermotor               11040
 Lucas                      DLB 101
Ignition coil (ballast type)
 Bosch                     0 221 119 030
 Commercial Ignition   IC8025
 Intermotor               11070
 Lucas                     DLB 102
Ballast Resistor
 Intermotor  11290
 Lucas    SCB400
Plug Lead Set
 Intermotor   73585
« Last Edit: November 07, 2009, 09:24:29 PM by tbone » Logged
« Reply #1 on: November 07, 2009, 06:43:39 PM »
Thanks for that Tim. We'll add it to our list of stuff to pinch from the forum & add to the main site.  Wink
« Reply #2 on: November 07, 2009, 07:59:49 PM »
 Wink
« Reply #3 on: November 07, 2009, 08:37:28 PM »
i may have some old stock  bosch spark plugs i bought a shed load a few years ago will try and look them out  soon
« Reply #4 on: August 01, 2011, 04:39:23 PM »
T bone,
Silly question, re points etc.. how can you tell if pre or post '81?
Did Reliant use different distributors for different years?
Cheers
Pete
« Reply #5 on: August 01, 2011, 07:39:24 PM »
They did, all but the very early ones will be type 45D, but they still used different points in them.
Only a subtle difference tho.  Wink
« Reply #6 on: August 02, 2011, 06:46:58 PM »
Tbone, Thanks again for the information  Smiley
