Title: Reliant engine service items part numbers Post by: tbone on November 07, 2009, 07:13:32 AM Hopefully these may be of some help to someone. All correct as far as i`m aware but as always please check before fitting.
Oil Filter Fram PH2834 Unipart GFE107 Champion C103 Air Filter Fram CA5634 Unipart GFE2361 Spark Plugs- pre 1996 NGK BPR5ES Champion RN12YC Bosch WR8D Spark Plugs - post 1996 NGK BCPR5ES BOSCH F8DCOR Contact Set Pre 1981 Bosch 1 237 013 834 Commercial Ignition CS132 Intermotor 22580 Lucas DSB 108 Motaquip VCS108 Unipart GCS2118 Contact set post 1981 Commercial Ignition CS179 Lucas DSB191 Motorcraft EDP109 Condenser Bosch 1 237 330 827 Commercial Ignition CON85 Intermotor 33720E Lucas DCB104 Motaquip VCD111 Motorcraft EDC151 Unipart GSC2109 Distributor Cap Bosch 1 235 522 843 Commercial Ignition XD79 Intermotor 44750 Lucas DDB108 Motaquip VDC108 Motorcraft EDH90 Unipart GDC136 Rotor Arm Bosch 1 234 332 848 Commercial Ignition R79 Intermotor 47540 Lucas DRB104 Motaquip VRA110 Motorcraft EDR63 Ignition Coil (non ballast resistor) Bosch 0 221 102 003 Commercial Ignition IC8029 Intermotor 11040 Lucas DLB 101 Ignition coil (ballast type) Bosch 0 221 119 030 Commercial Ignition IC8025 Intermotor 11070 Lucas DLB 102 Ballast Resistor Intermotor 11290 Lucas SCB400 Plug Lead Set Intermotor 73585 Title: Re: Reliant engine service items part numbers Post by: Manky Monkey on November 07, 2009, 06:43:39 PM Thanks for that Tim. We'll add it to our list of stuff to pinch from the forum & add to the main site. ;)
Title: Re: Reliant engine service items part numbers Post by: tbone on November 07, 2009, 07:59:49 PM ;)
Title: Re: Reliant engine service items part numbers Post by: spanners on November 07, 2009, 08:37:28 PM i may have some old stock bosch spark plugs i bought a shed load a few years ago will try and look them out soon
Title: Re: Reliant engine service items part numbers Post by: trikerpete on August 01, 2011, 04:39:23 PM T bone,
Silly question, re points etc.. how can you tell if pre or post '81? Did Reliant use different distributors for different years? Cheers Pete Title: Re: Reliant engine service items part numbers Post by: tbone on August 01, 2011, 07:39:24 PM They did, all but the very early ones will be type 45D, but they still used different points in them.
Only a subtle difference tho. ;) Title: Re: Reliant engine service items part numbers Post by: trikerpete on August 02, 2011, 06:46:58 PM Tbone, Thanks again for the information :)
