March 07, 2026, 09:54:38 AM
General Tech
Reliant engine service items part numbers
Topic: Reliant engine service items part numbers (Read 21431 times)
November 07, 2009, 07:13:32 AM »
Hopefully these may be of some help to someone. All correct as far as i`m aware but as always please check before fitting.
Oil Filter
Fram PH2834
Unipart GFE107
Champion C103
Air Filter
Fram CA5634
Unipart GFE2361
Spark Plugs- pre 1996
NGK BPR5ES
Champion RN12YC
Bosch WR8D
Spark Plugs - post 1996
NGK BCPR5ES
BOSCH F8DCOR
Contact Set Pre 1981
Bosch 1 237 013 834
Commercial Ignition CS132
Intermotor 22580
Lucas DSB 108
Motaquip VCS108
Unipart GCS2118
Contact set post 1981
Commercial Ignition CS179
Lucas DSB191
Motorcraft EDP109
Condenser
Bosch 1 237 330 827
Commercial Ignition CON85
Intermotor 33720E
Lucas DCB104
Motaquip VCD111
Motorcraft EDC151
Unipart GSC2109
Distributor Cap
Bosch 1 235 522 843
Commercial Ignition XD79
Intermotor 44750
Lucas DDB108
Motaquip VDC108
Motorcraft EDH90
Unipart GDC136
Rotor Arm
Bosch 1 234 332 848
Commercial Ignition R79
Intermotor 47540
Lucas DRB104
Motaquip VRA110
Motorcraft EDR63
Ignition Coil (non ballast resistor)
Bosch 0 221 102 003
Commercial Ignition IC8029
Intermotor 11040
Lucas DLB 101
Ignition coil (ballast type)
Bosch 0 221 119 030
Commercial Ignition IC8025
Intermotor 11070
Lucas DLB 102
Ballast Resistor
Intermotor 11290
Lucas SCB400
Plug Lead Set
Intermotor 73585
Last Edit: November 07, 2009, 09:24:29 PM by tbone
Re: Reliant engine service items part numbers
November 07, 2009, 06:43:39 PM »
Thanks for that Tim. We'll add it to our list of stuff to pinch from the forum & add to the main site.
November 07, 2009, 07:59:49 PM »
November 07, 2009, 08:37:28 PM »
i may have some old stock bosch spark plugs i bought a shed load a few years ago will try and look them out soon
trikerpete
August 01, 2011, 04:39:23 PM »
T bone,
Silly question, re points etc.. how can you tell if pre or post '81?
Did Reliant use different distributors for different years?
Cheers
Pete
August 01, 2011, 07:39:24 PM »
They did, all but the very early ones will be type 45D, but they still used different points in them.
Only a subtle difference tho.
trikerpete
Reply #6 on:
August 02, 2011, 06:46:58 PM »
Tbone, Thanks again for the information
