November 04, 2025, 09:47:23 PM *
Pages: 1 ... 3 4 [5] 6 7 ... 10
Author Topic: trike build  (Read 41512 times)
trikerpete
« Reply #60 on: March 26, 2010, 08:04:02 PM »
Thanks andy. they belong to the boss Grin Grin
What you doing wearing her slippers.... you'll be wearing her dresses next Wink Grin Grin Grin
« Reply #61 on: March 26, 2010, 09:39:11 PM »
Then it will be undies.
klogan45
« Reply #62 on: March 28, 2010, 03:41:24 PM »
Ooooooooooer missus, then the stockings,,,,,,,,,
« Reply #63 on: April 09, 2010, 10:06:27 PM »
v5c arrived today 13 weeks afther being inspected. fitted new tyre steering a bit better.but you can fill it pulling trying to pull straight when you power up on bends or going around round abouts. still looking at altering forks
« Reply #64 on: April 10, 2010, 06:05:07 AM »
The effects you describe are perfectly normal for a trike ie ploughing when powering around corners you won't get rid of that ever.
Just use the biggest tyre you can find to get the biggest amount of rubber on the road.
trev
« Reply #65 on: April 10, 2010, 08:30:43 AM »
yeh what TP said is right,youve got to learn to ride it,changing forks could make it worse.
« Reply #66 on: April 10, 2010, 09:23:10 PM »
Once you get used to it you don't even notice it!  And it will be much less marked at higher speeds.
« Reply #67 on: April 10, 2010, 10:37:56 PM »
thanks for all you comments.i know i will get use to it in time.but it don't fill right compared to my old 550. witch you could ride one handed in to bends. i have checked the trail and its about 5 1/2".when checking other sites they say.alter the head stock by about 5degrees. or alter the forks by making them longer ie springer/girder or fit leading link.some say alter the triple trees.to give about a 2" trail. i will still ride it but will be looking at different alterations. terry
« Reply #68 on: June 03, 2010, 07:09:02 PM »
Heavy steering update. got a local engineer to make these. hopefully to reduce the steering trail down from about 5" to 1 1/2"
will be fitting them this weekend.
http://i47.tinypic.com/x43u6r.jpg
trike build
http://i50.tinypic.com/1zwyxb4.jpg
trike build
http://i50.tinypic.com/2sajg1z.jpg
trike build
Mr_G
« Reply #69 on: June 03, 2010, 07:57:12 PM »
How have I missed this thread so far? Loving the build Terry.
« Reply #70 on: June 04, 2010, 09:39:54 AM »
That looks like it works on the same principle as the 'Easysteer' produced by a somerset trike builders.....
Cabman77
« Reply #71 on: June 04, 2010, 02:22:05 PM »
It all becomes clear to me now  Grin Grin Grin Grin
cunningplan
« Reply #72 on: June 04, 2010, 05:08:13 PM »
and me Shocked
« Reply #73 on: June 09, 2010, 09:33:49 PM »
Hi BikerGran. yes they are  based on that system. i phoned them up and had a chat with with the boss.told me they don't make them for goldwings. i think they only will make if they built the trike.so i went else were to get these made
http://i48.tinypic.com/xgi21.jpg
trike build
« Reply #74 on: June 09, 2010, 09:43:21 PM »
Which will look like this
http://i50.tinypic.com/opwjyt.jpg
trike build
http://i45.tinypic.com/e8nwhu.jpg
trike build
and reduce the steering trail down from 5 1/2" to 2" and make the steering lighter
