November 04, 2025, 05:50:47 PM *
Pages: 1 2 3 [4] 5 6 ... 10
Author Topic: trike build  (Read 41491 times)
trikerpete
« Reply #45 on: March 23, 2010, 10:00:04 PM »
thanks terry
heavy steering.... have you heard of "easy steer"
http://www.wackeystrikes.co.uk/vir11.htm
« Reply #46 on: March 23, 2010, 10:22:10 PM »
Hi morrag. thanks for your reply.yes i know that these type of forks are expensive.so  i am looking at fitting external springs to the forks [as in photo] and fitting a car type tyre to the front wheel
« Reply #47 on: March 23, 2010, 11:41:21 PM »
I have my doubts as regards the effectiveness, or value, of that type of auxiliary spring. I tend to agree with Mr M, that if the most effective route of Earles type fork is not persued, then the rake and trail must be adjusted, along with shorter,stiffer,but not necessarily overly stiffly sprung, larger stanchion forks, are required, cheers, Morrag
nabsim
« Reply #48 on: March 24, 2010, 01:57:21 PM »
I am going to make leading links for my trike. I had them on an outfit and the difference it made was unbelievable. Would buy a nice shiney new set but seeing as the run at around a grand it isn't an option
trikerpete
« Reply #49 on: March 24, 2010, 09:23:00 PM »
when you make them, dont forget to post details/dimensions etc Smiley
nabsim
« Reply #50 on: March 25, 2010, 01:36:19 PM »
Shall make sure they work and stay straight before I post anything Wink
trikerpete
« Reply #51 on: March 25, 2010, 05:50:26 PM »
said the wise man Wink Smiley
« Reply #52 on: March 25, 2010, 10:33:30 PM »
Hi all. tyre came today. going to take a day off work tomorrow so will try a fit it then. with a bit of luck the springs will be here tomorrow so i can sort them out as well
http://i39.tinypic.com/96ykqe.jpg
trike build
http://i44.tinypic.com/2rwrw5w.jpg
trike build
« Reply #53 on: March 25, 2010, 10:35:37 PM »
Nice slippers Terry.  Kiss
« Reply #54 on: March 25, 2010, 10:37:43 PM »
Thanks andy. they belong to the boss Grin Grin
VmaxTriker
« Reply #55 on: March 26, 2010, 01:06:06 AM »
Does the flat face tyre make the steering seem any more heavier (for those that already use them)
If only someone would produce affordable leading link forks, cos I need em too  Grin
Ignite the Vboost!!!
trev
« Reply #56 on: March 26, 2010, 09:24:59 AM »
how much was the tyre terry? might try one myself.
« Reply #57 on: March 26, 2010, 12:09:33 PM »
Hi trev. £59 free p/p.ebay  item no 260563494614
advertised as side car tyre .going to fit today
« Last Edit: March 26, 2010, 12:31:10 PM by terry t » Logged
nabsim
« Reply #58 on: March 26, 2010, 01:24:21 PM »
Is that an Avon Tourist vintage car tyre? It looks like the ones I had on the front of my outfits.
« Reply #59 on: March 26, 2010, 02:33:56 PM »
Hi yes it is an avon. triple duty 350/19 trye. suitable for sidecar and the older light cars ie Austin 7
