November 04, 2025, 05:41:50 PM *
Pages: 1 ... 8 9 [10]
Author Topic: trike build  (Read 41483 times)
« Reply #135 on: May 30, 2011, 12:12:39 PM »
My Baby's.broke again  Cry.
went for a run after giving it a service.ran fine up to speed no problems.then lost drive  Angry prop spins but wheels don't turn.lucky i was only 50yards from home.still f---- from pushing it back.
i just want to ride it not keep repairing it.
in garage now taken back axle of to see whats wrong
zakboy
« Reply #136 on: May 30, 2011, 12:32:08 PM »
sorry to hear that terry, is your axle shortned ,the shafts not broke at the joint as it
« Reply #137 on: May 30, 2011, 03:33:24 PM »
Hi Zac. Yes it has had the axle shortend.and its weakest point will be the halfshaft
zakboy
« Reply #138 on: May 30, 2011, 03:55:10 PM »
well i hope you can get it sorted soon mate. zak
« Reply #139 on: May 31, 2011, 07:58:24 AM »
Well after stripping it down only to find. the halfshaft welded join did fail.
http://i54.tinypic.com/zsvfa.jpg
trike build
http://i55.tinypic.com/250i0wn.jpg
trike build
http://i51.tinypic.com/2m3kye0.jpg
trike build
lucky for me it was pinned or it could have bean worst.axle shaft and diff could have bean buggered up
« Reply #140 on: May 31, 2011, 04:10:39 PM »
All fixed now  Wink
klogan45
« Reply #141 on: May 31, 2011, 08:22:20 PM »
Show me, show me, show me!!!
How did you fix that? You must be bloody good.
« Reply #142 on: May 31, 2011, 10:39:45 PM »
The pic. would suggest little or no weld penetration on that half shaft, so with a proper weld prep. and a welder who knows his biz. the repair will be fine, and would the orig.  have been had that been prepared and executed correctly. I have shortened a number of half shafts in a similar manner,i.e. by machining to to press fit and welding, with no probs. to date, Morrag.
« Reply #143 on: June 01, 2011, 08:02:59 AM »
I dont know i took it to a machine shop the have it shortend and welded.i said about sleeving it and they said it will be ok.
IT PROBERLY BROKE BECAUSE I HAVE BEEN GIVING IT SOME STICK 0 TO 60 IN 6 SEC  Grin
AND USING THE GEAR BOX TO SLOW DOWN MAINLY TO TEST THE STEERING AND HANDLING IT DO SHIFT  Shocked
Any way thats history now. i cleaned it up and wound the MiG up and re welded it around the shaft. then i put a sleeve with a cut line through it over the shaft. cramped it in the vice then welded down the sleeve and around the ends.then drilled 6 holes three in each half about 10mm deep then filled them with welds.cleaned up and this is it
http://i56.tinypic.com/2vjdj5u.jpg
trike build
http://i52.tinypic.com/dokoqh.jpg
trike build
all back together again
