November 04, 2025, 05:45:02 PM *
Pages: 1 [2] 3 4 ... 10
Author Topic: trike build  (Read 41487 times)
« Reply #15 on: September 21, 2009, 07:58:40 PM »
That looks like its gonna be a very narrow rear axle. It doesn't look like you can fit a diff in before the axle clamp. You gonna be able to lean that like a solo? Wink
How wide is the rear end gonna be?
« Reply #16 on: September 21, 2009, 09:02:23 PM »
yes it's narrow it's 39 inches between back plates and 51 inches overall width
more pictures to follow
« Reply #17 on: September 21, 2009, 09:09:21 PM »
a view from the back of the swinging arm
rear side view of rear axle
view from the other side
the axle and frame view from the rear
pictures of trike on wheels to follow
« Reply #18 on: September 22, 2009, 12:22:50 PM »
Wow, that is a good fit Smiley
Do you know what model that axle/diff came off as that is the same as mine, well would be if it was black? Wink
« Reply #19 on: September 23, 2009, 12:59:20 PM »
Looking good. I take it that the bike has same propshaft rotation as reliant?
« Reply #20 on: September 23, 2009, 09:27:11 PM »
hi nabsin it came of a 1985 reliant robin "b" type axle
harley gazz
« Reply #21 on: September 23, 2009, 11:48:22 PM »
did an aspencade a few years back and after the first fire up  Angry Angry Angry had to flip the axle as i had accquired 6 reverse gears ,instead of 6 forward ones hope ya got it right  Wink
arc eye tha noo
« Reply #22 on: September 24, 2009, 11:00:41 AM »
Same thing on the first trike I ever built, an XS750 Yam. I'd narrowed the axle on one side to line up with the bike engine output, so when I had to flip the axle upside down, it was twice as far out of line. Had to start all over again.
The majority of bike engine props rotate the opposite way to Reliants, so hope you've checked it mate.  Wink
« Reply #23 on: September 24, 2009, 12:45:15 PM »
I thought I read something by desperate saying you didn't need to flip the reliant axles as you can open the diff and swap the gears over?
« Reply #24 on: September 24, 2009, 04:01:45 PM »
Someone here has mentioned that in the past, but as one side of the casings is much deeper than the other, wouldn't that involve flipping the casings anyway?
« Reply #25 on: September 24, 2009, 04:52:32 PM »
Being a Honda Goldwing it's probably similar to my Silverwing final drive output shaft/direction,which was the same as this one, anyway, if not you can flip the internals of these axles as the planet wheels are still contained in the main casting area, Morrag
« Reply #26 on: September 24, 2009, 06:08:53 PM »
Problem solved, should it arise then.  Wink
« Reply #27 on: September 24, 2009, 08:05:29 PM »
hi reading all comment on the prop shaft rotation. the goldwing is the same as the reliant axle. when i decided to build a trike i had it on the bench for about 3 mts working out how i would do the swinging arm convertion. making templates out of ply to keep it as compacked as possible.checking the prop rotation ect  using string lines levels to keep the axle square to the frame.before cutting the axle and swinging arm.then made a jig for the swinging arm and axle to sit in so i could cut the box section to fit
« Reply #28 on: September 24, 2009, 09:12:27 PM »
And made a nice job of it too.
« Reply #29 on: September 24, 2009, 09:19:47 PM »
thanks for that mm.hows your trike coming along. is rent a monkey adoption still open
