Hillbilly Deluxe
« Reply #45 on: May 29, 2009, 04:56:23 PM » |
If i had to use it,i would drop it down,and back,but i agree with MM on the other style.IMO it just does'nt fit.
« Reply #46 on: May 29, 2009, 06:04:07 PM » |
Hmmm just been out to have another look........The passenger rear part does look high ,but I think the front part(driver)is ok, it follows the sweep of the tubes from main rail toward axle,and then flicks up into a sort of backrest.Maybe I'll sorta chop off the rear part and leave the front with its upswept backrest , using the covering of the chopped off bit to re-upholster the back face of the backrest. Been offered it at a fair price so maybe worth doing.
« Reply #47 on: May 29, 2009, 08:55:51 PM » |
Sounds O.K, give it a go. What have you got to lose.
« Reply #48 on: May 30, 2009, 06:58:26 AM » |
After looking at this in the cold light of day ,over my first cup of tea this morning,in the garage!I realise I was wrong to get carried away with the Harley seat. It does really need a single lower seat ,with a seperate rear one!
Hillbilly Deluxe
« Reply #49 on: May 30, 2009, 11:11:37 AM » |
Go for it ! you could make the pillion bit QD.
« Reply #50 on: May 30, 2009, 04:20:59 PM » |
QD as in Quickly Detachable. Muffin made up a pillion seat for his black Reliant trike, which clips to the luggage rack bit of the frame with 4 R clips. I wouldn't want to dictate what anybody builds -I love the variety here & the way different people see completely different answers to problems, but I've made the mistake myself several times of being determined to incorporate a feature into a build & finding almost everything else around it would need to be altered to accomodate it. Lots & lots of alternatives you can use, but maybe some things just "work" & others don't?
« Last Edit: June 09, 2009, 09:33:37 PM by Manky Monkey »
« Reply #51 on: June 09, 2009, 06:10:48 PM » |
Nearly stripped ready for final weld of frame.......  (the strap across the down tubes is temporary,just to hold them together while a cross tube is added.)
Mr_G
« Reply #52 on: June 09, 2009, 08:30:32 PM » |
Let me be the first to tell you that......................................................................it's upside down  Good luck chap, hope all goes to plan. Keep us posted.
« Reply #53 on: June 09, 2009, 09:35:36 PM » |
My, you've been a busy Bunny! Looks great Rod.
pie
« Reply #54 on: June 11, 2009, 08:16:23 PM » |
Just had a quick look at the frame Rod, looking good! let me know when you're going down again and i'll try and get down there on my trike.
tony b
« Reply #55 on: June 11, 2009, 11:36:05 PM » |
whats an R clip
« Reply #56 on: June 12, 2009, 04:02:42 AM » |
One of these Tone.
blair
it looks bigger in water ! !
« Reply #57 on: June 12, 2009, 07:47:46 AM » |
its the thing that hold the swivel pin of a sky hook
tony b
« Reply #58 on: June 12, 2009, 02:35:05 PM » |
fanks andy
yanto
« Reply #59 on: June 12, 2009, 03:31:07 PM » |
