April 17, 2026, 06:48:48 AM *
Pages: 1 ... 26 27 [28] 29 30 ... 65
Author Topic: RODS build........  (Read 330621 times)
RODeo
« Reply #405 on: November 06, 2011, 04:42:54 PM »
I got 2 copies from the weighbridge,sent one of them ,and made copies of everything else!
« Reply #406 on: November 06, 2011, 05:10:14 PM »
Looking very tidy Rod. Love the colour. How did you form the lip around the air filter cover?
RODeo
« Reply #407 on: November 06, 2011, 05:27:11 PM »
Thanks Andy. The two plates are 6 mm aly rough cut with a jigsaw. I drilled a hole in the centre for a 10mm bolt . Bolted them together then spun them in the lathe to make a 'pair' . Then I ran a groove about 4 mm deep very close to the edge in each one . I used the mesh from an old pancake filter and cut it down so that it exactly fits in width between the 2 plates, in the grooves. The plates are spaced apart with a top hat section held onto the 'base' plate by the bolts that hold the base to the carb.Didnt think the mesh was fine enough,so used a piece of very fine mesh (the stuff you can buy at builders merchants that they use in roof soffitt vents to keep out bugs etc) to back the larger mesh.
steve brock
« Reply #408 on: November 06, 2011, 05:53:19 PM »
Hi how do your mudguards attach to the frame? That my next job Smiley
RODeo
« Reply #409 on: November 06, 2011, 08:03:06 PM »
Hi SB. I extended upward the axle clamp (the half that is attached to the frame) You can see it in the second guard pic.
steve brock
« Reply #410 on: November 06, 2011, 10:01:21 PM »
I C... Not quite how I'm gonna do it but may nick that idea Smiley are your mudguards steel ? I just bought these
http://item.mobileweb.ebay.co.uk/viewitem?itemId=110681605574&kw=110681605574
« Reply #411 on: November 06, 2011, 10:37:26 PM »
Steve,
         What size tyres are you wrapping them around?
Cheers Smiley
steve brock
« Reply #412 on: November 06, 2011, 10:49:51 PM »
I got 15" wolfrace slot mags with 195 tyres on
RODeo
« Reply #413 on: November 07, 2011, 04:35:50 PM »
I didnt want the complete wraparound look,hence why I chopped up mine.I used one trailer guard to make both of mine.As you can see,the rear of mine stop exposing the tyre when looking straight down from the top. I realised this at the outset,and decided to make up some stainless 'mudflaps' mounted on brackets protruding from the rear of the guards following the wheel closely, to stop a wall of water off each tyre!
  UPDATE on my test application..I phoned them back with the numbers they wanted ..5500 rpm,and they are going to contact me with a firm date tamara.I cant have my preffered (sp?) date so I may have to move one of my days holiday from work to accomodate .Looks like being December 21st.I didnt realise it was a 3 hour test! Ive also got to take a crash helmet. Looks like I'll have to buy one sooner than I thought!
« Last Edit: November 07, 2011, 04:53:33 PM by RODeo » Logged
thebigdogsix
« Reply #414 on: November 07, 2011, 04:53:04 PM »
To be honest they told me 3 hours as well it was nearer to an hour and a half. I think they just allow for that long
No idea what the crash helmet is for though  Huh well not for the test anyway as for the figures you were after i just robbed it out the haynes manual  Smiley
RODeo
« Reply #415 on: November 07, 2011, 04:54:59 PM »
I couldnt find it in the manual! They told me to bring the crash helmet as I may have to ride it in the yard .
thebigdogsix
« Reply #416 on: November 07, 2011, 04:56:53 PM »
I had to ride it to the shed from the waiting area but he never asked me to wear a helmet (just as well i never took one)  Smiley
RODeo
« Reply #417 on: November 07, 2011, 04:59:21 PM »
Well Ive gotta get one sooner or later,so will try to find time to go to a large bike shop nearby,that apparently has a wide choice.
mukit
« Reply #418 on: November 07, 2011, 08:31:18 PM »
and you need a helmet for?  Wink
i was doin 70 down the m3  Wink Wink  yesterday bumbling past ppl everyone was staring for some reason maybe my flies were undone lol
« Reply #419 on: November 07, 2011, 09:23:02 PM »
-you don't legally need a crash helmet on a trike.
