mukit
« Reply #420 on: November 07, 2011, 09:41:29 PM » |
but it doesnt stop the cops doing a double take as you overtake them
« Reply #421 on: November 08, 2011, 08:35:54 AM » |
RODeo
« Reply #422 on: November 08, 2011, 01:14:13 PM » |
Apparently when I have to move it in their yard,I need a helmet.Thats waht they told me anyway.
« Reply #423 on: November 08, 2011, 07:54:44 PM » |
Fair enough. If it makes them happy & helps you pass the test, who cares!
RODeo
« Reply #424 on: December 15, 2011, 03:04:04 PM » |
So ,Im counting the days to the test now(next Weds!) My main problem has been finding somebody to come along to Norwich test centre with me,to help unload/load the thing ! My 2 sons are both busy at work.I asked about 10 people and everyone was busy,phoned the centre and asked if anyone there could help,but no joy.I think at last I may have found a lad to help. Just praying he turns up on time on the day! Its not going to be cheap though! Im not too fussed if it fails cos then at least I have a list to work to,but its obviously going to cost another wad of money to have to go back up there for a retest!We'll see!
« Reply #425 on: December 15, 2011, 10:21:05 PM » |
Fingers crossed for you mate.
thebigdogsix
« Reply #426 on: December 15, 2011, 10:36:25 PM » |
Good luck with the test Rod
zakboy
« Reply #427 on: December 16, 2011, 11:20:11 AM » |
All the best with the test Rod
RODeo
« Reply #428 on: December 18, 2011, 10:43:09 AM » |
Testing in the car park today...it was COLD out there! Happy I managed a short run,went out again ,its now snowing,so back in the garage! A couple of small puffs of blue smoke from the oil filler after a few circuits of the car park,but Im putting that down to the engine been standing for a while(and the cooling fan wasnt switched on!)Hoping it will de- gunk a bit after a bit of running.
« Last Edit: December 18, 2011, 11:21:52 AM by RODeo »
thebigdogsix
« Reply #429 on: December 18, 2011, 11:34:35 AM » |
Hi Rod trike looks great just noticed on your pic that your master cylinder is covered with some straps. can you still get the lid off the master cylinder without removing them?
RODeo
« Reply #430 on: December 18, 2011, 12:37:22 PM » |
No! I read in the MSVA manual that the m/cyl must be (easily) accessed,so I thought that 4 x 6mm bolts on the cover would be ok? Or does the top have to be completely clear?
thebigdogsix
« Reply #431 on: December 18, 2011, 12:54:57 PM » |
If you need to remove anything to gain access to the master cylinder then the tool required must be in the tool kit on the trike and not in your pocket hth  This is copied from 100% biker forum they have a bloke on there that works for vosa and i asked the question what does easily checked mean Hi Dan, We had to come up with a definition of easily checked in the early days because the EU didn't bother to specify what they meant (no surprise there). It's the note just below 12, if you can take the lid off by hand that's fine, if it has a viewing window or is translucent so that you can see the level that's fine too. If the reservoir is solid and the lid needs tools to remove it then the tool required must be part of the vehicle equipment. So the allen key or screwdriver or whatever needs to be on the trike and not in your pocket. Hope this helps. Cheers Chris
« Last Edit: December 18, 2011, 01:01:30 PM by thebigdogsix »
« Reply #432 on: December 18, 2011, 01:21:22 PM » |
Looking realy good Rod.  Good luck with the test.
Al
« Reply #433 on: December 18, 2011, 02:05:11 PM » |
it is looking good all that hard work has paid off
RODeo
« Reply #434 on: December 18, 2011, 03:59:31 PM » |
Thanks everyone for the sentiments..... Ive now altered the m/cyl cover. Looks c**p,but I will getaway with it, then change it after the MSVA.Oh ,and in my haste to get it sorted I managed to break a drill bit as I drilled it,which then went into my hand! Hey Ho!
« Last Edit: December 18, 2011, 04:15:42 PM by RODeo »
