April 05, 2026, 12:32:23 AM *
Pages: 1 ... 51 52 [53] 54 55 ... 63
Author Topic: Tazet's Trike project :)  (Read 339714 times)
« Reply #780 on: March 23, 2010, 08:52:16 PM »
No idea why, but I just like vintage tractors & the greys are my favourites. You can buy a decent condition one for about 2 grand. Great fun around the lanes where we live, but can't see me commuting to work down the M3 on one somehow.
« Reply #781 on: March 24, 2010, 04:01:27 PM »
looking good Andy, going to be cool along side the Pop and Charger  Cool Cool Cool
« Reply #782 on: March 24, 2010, 10:51:29 PM »
And my trike?
« Reply #783 on: March 25, 2010, 07:27:24 PM »
never be finished  Grin Grin Grin Kiss
« Reply #784 on: March 25, 2010, 11:01:58 PM »
Bleaurgh!  Tongue
« Reply #785 on: March 26, 2010, 05:26:52 PM »
 Kiss Kiss Kiss Kiss
« Reply #786 on: March 29, 2010, 07:11:44 PM »
Don't know why, but I just can't get motivated to get anything done on our various projects at the moment, which is annoying cos there's so much to do. I've had most of the weekend to myself so should've ploughed on with the 2 trikes, but failed miserably.
It's been pouring down here all day -finally got into the shed & spent an hour or so being dripped on from the leaky roof while I cleaned up the heated manifold for Taz's trike. I've hacksawed, (hacksawn?), the inlet & outlet pipes off the back of it, then filed the remainder off before cleaning it up with some wet n dry. So now it's a nice slimline S bend sort of shape.
« Reply #787 on: March 29, 2010, 07:31:25 PM »
Very shiny! Will you be taking that wet n dry to the manifold too?
« Reply #788 on: March 29, 2010, 07:57:08 PM »
But of course -eventually.
gpz
« Reply #789 on: March 29, 2010, 08:54:39 PM »
i know what u mean cant seem to get motivated at the moment ,i stood looking the other day and decided that the rack at the back was not square so it will have to be cut off and re done but better now than later also busy with work  if it would stop raining could maybe get something done
« Reply #790 on: April 14, 2010, 03:57:58 PM »
Well the rain's finally stopped so that's that excuse gone. Still not getting anywhere with either Taz's or my trikes though. Neither has really moved on much in the last year. We just seem to be so busy all the time, that when we finally get some free time, I'm too knackered to think about getting in the shed.
Taz & I were at the Dorking Harley swapmeet in Surrey on Sunday morning. I wasn't really looking for anything, but still picked up another carb bellmouth. The previous one's chromed pressed tin. This one's huge & much beefier, in thick, cast aluminium. A bargain for 10 quid. Obviously it's intended for a Harley & sweeps round through 90 degrees.
I half thought of fitting it on my own trike, but it suits Taz's more heavy duty machine much better. So I'll use her previous bellmouth on my trike & fit this one to hers. I'll need to make an adaptor plate to convert from the 3 bolt bellmouth fitting to the 2 bolt SU carb though.
« Reply #791 on: April 14, 2010, 04:01:57 PM »
you ain't the only one mate  Grin Grin Grin still my ever decreasing project collection should make it easier for me  Undecided Undecided Roll Eyes
« Reply #792 on: April 14, 2010, 07:40:42 PM »
ooh thats nice! Cant get any enthusiasm for my heap either at the moment, been a month since i last looked at her, hopefully the better spring weather will give me the kick up the arse i need!
« Reply #793 on: April 22, 2010, 10:35:18 PM »
This evein' oi 'ave mostly bin...
making the adaptor plate to fit Taz's new bellmouth to her SU carb.
Started with an offcut of 6mm steel plate, blagged from Lunatic -who blagged it from Doug.
I used a large hole saw in a hand drill to cut the centre hole out. The slot is to feed air to the choke jet. Then I drilled & tapped 2 M8 mounting holes & cut down a couple of M8 bolts to create short studs, screwed them in, so the ends were below the surface of the plate, then filled the holes with weld & flushed them off with a soft pad on the angle grinder.
That gave me a pair of M8 studs on one side of the plate. I drilled the Imperial mounting holes on the carb out to 8mm so the studs would pass through, & secured them with a couple of dome nuts & spring washers.
« Last Edit: April 22, 2010, 10:37:22 PM by Manky Monkey » Logged
« Reply #794 on: April 22, 2010, 10:40:51 PM »
With the plate secured to the carb, I just needed to fix the bellmouth to the plate.
That's why I used 6mm steel. I drilled the 3 bellmouth mounting holes & tapped them to M6. Some short M6 allen bolts & the whatsit's fitted to the thingumy.
