April 22, 2026, 01:22:22 PM *
Pages: 1 ... 18 19 [20] 21 22 ... 36
Author Topic: A little progress  (Read 160777 times)
« Reply #285 on: June 19, 2013, 10:05:06 PM »
to finish the wiring completely i need to fit the dash so...
http://i1056.photobucket.com/albums/t373/Eddie096/82F072F0-05E1-4A0F-8AEC-1E4E0DB17DE1-8094-00000EF3A5B949FA_zpscde4726a.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/617CBEB6-935B-490D-BA4F-A41C1CE2A2B0-8094-00000EF3B161D63E_zpsaaa9186b.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/AA9D1C50-36F4-4180-9258-DA076DA42C51-8094-00000EF3C426B93A_zps52aadef0.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/E431D986-7DDB-4CD9-A410-874C5AD7D780-8094-00000EF3CEFFD060_zpsa3a35f97.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/2EBE695D-7E98-496A-911D-4AFBECBC73C7-8094-00000EF3D92356AD_zpsb1e5dcaf.jpg
A little progress
need to trim the tanks to let the clocks down but it's getting there,just thought i'd reuse the original
clocks as i had em and they sort of fit the style of the dash... i think Smiley
« Reply #286 on: June 23, 2013, 09:11:51 AM »
made a towing dolly yesterday evening as the trike has to go to have an alloy petrol tank made
http://i1056.photobucket.com/albums/t373/Eddie096/4F99E5FA-2517-41AD-8531-717235E88BF3-8597-000010175C09963B_zpscab544b9.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/1B6E0ECC-B9E5-40C1-846E-40CCAC258AFB-8597-0000101766AAC150_zps88a5f145.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/2778D231-BA07-4808-893D-32A6CC83BF08-8597-0000101771E68E66_zpse07b8c0b.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/58D4BE2D-DB33-4DCF-92CB-C9E4B394957E-8597-000010177BBF8B41_zpse384c0a7.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/1B00331B-C30F-4D86-AA56-C88CA52AC992-8597-000010179BE2AE9B_zpsd76589f8.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/DA8A6C5D-794A-4FC9-8B0F-962181A45340-8597-00001017B3E32041_zpsbeab1be8.jpg
A little progress
and in use for a quick trial
http://i1056.photobucket.com/albums/t373/Eddie096/6F66F44D-AC96-4692-80AC-880B9ED7B17C-8597-00001017DF32076B_zps25a2076e.jpg
A little progress
hope the video work's havn't did that before!
attached to the frame so no double articulation the only disadvantage is you have to lift it on to the car your towing it with but at the minute i have no problem doing that
« Last Edit: October 15, 2014, 06:14:31 AM by scannerzer » Logged
« Reply #287 on: June 23, 2013, 10:05:00 AM »
mmm video didn't work mmm Huh Huh
« Reply #288 on: June 23, 2013, 10:54:21 AM »
i'll try this
http://www.youtube.com/watch?v=t4z3HmIT4Jk
« Reply #289 on: June 23, 2013, 10:55:36 AM »
yeeeeeeha it worked
« Reply #290 on: June 23, 2013, 12:59:17 PM »
Yes it works and a good job done
« Reply #291 on: June 23, 2013, 10:26:02 PM »
thanks Merv i think it will do the job, just need to replace the bolt with a steel pin and it should be good to go
zakboy
« Reply #292 on: June 24, 2013, 02:57:19 PM »
this as come on leaps and bound since i last took a look..... good work and well done
« Reply #293 on: June 25, 2013, 09:26:33 PM »
thanks guys Smiley
well on to the brakes,do you wish you'd never started something,fecking brake fluid fecking everywhere from every ,joint brake end, EVERYWHERE Angry Huh
does anyone know if copper/nickle alloy is harder to get sealed than just plain copper? Alan who's helping me is a mechanic and has a good flairing tool so that's not the problem but we had to tightin every joint to
almost striping point to get the leaks to stop but all sorted now.
Piped for split brakeing 2 rear one front,need to finish the pedal and get some new front pads and then we can test it out.
http://i1056.photobucket.com/albums/t373/Eddie096/0F7871A7-B269-49AD-A93E-7EB5046097B2-8597-00001017EC8066F9_zpsbbf97ba4.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/03E81975-0E79-419D-93BE-227643ED4AB8-9097-0000111D2ACD0BB0_zps4c87c2fe.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/23A81AE1-A54E-4A05-8505-2433E5DC5B40-8597-00001017FE77E12E_zps0376ec1a.jpg
A little progress
how good should the brakes be with this setup ? and at least we will know we are ball park.
front end dives slightly and rears lock if you stand on the pedal with about 1 1/2 inches of travel does this sound about right,I've never even riden a trike so don't know what to expect Roll Eyes Roll Eyes
thanks eddie
« Reply #294 on: June 28, 2013, 10:39:52 PM »
pedals finished
http://i1056.photobucket.com/albums/t373/Eddie096/41AC9A81-4030-45FC-A4BD-662A983039A6-9692-000011A7D29C29F3_zpse7251d13.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/C7CBAB42-DC1F-4BFD-876E-3D462C462A40-9692-000011A7DB240B8F_zpse19cdecc.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/53445505-9CEB-427E-8591-76DB8A689F85-9692-000011A7E5CBB9D1_zps20eb67d2.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/8F98E91A-C935-4C8B-A915-03F1D795DA5C-9692-000011A7EFC8F530_zpsbc425d83.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/FB52187B-B9CA-4776-9E8C-16D3A8C254AB-9692-000011A7FF71B1C5_zps7e9f6cb2.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/A3BE1A4A-2D81-4BFB-9016-86ADE7B9E7E4-9692-000011A80763567D_zps030ce166.jpg
A little progress
« Reply #295 on: June 28, 2013, 10:42:03 PM »
and steering lock
http://i1056.photobucket.com/albums/t373/Eddie096/E76F4203-CD29-48D4-A497-A6EF14517E53-9692-000011A80EA39F0C_zpscc79d43f.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/BC725F88-33F8-4976-8B6D-EAC45E7B8F4A-9692-000011A816A78152_zps81c2f655.jpg
A little progress
this will also act as a steering stop
« Reply #296 on: June 29, 2013, 06:54:06 AM »
Nice progress there.
does anyone know if copper/nickle alloy is harder to get sealed than just plain copper? .
Kunifer pipe is slightly more ridged than plain copper but I have never had any problems. Did you lubricate the flaring dies?
You definitely want the backs to lock before the front  Grin (locking up the front on a busy, wet roundabout is NOT fun) Should be able to do so with a hard push from the seated position. Until you get it on the road and the brakes all bed in it's difficult to tell how they will behave.
« Reply #297 on: June 29, 2013, 07:53:13 AM »
Thanks ON you have just answered several of my questions.yes dies were lub'ed ok but they just seem to need that little extra nip up to stop leak's probably accounted for by the extra hardness and now with the pedals finished the brakes feel much better but as you say need bedding in.
If all else fails I'll put an adjustable regulator on the back bone where the copper meets the braided hose if front end locking happens
« Reply #298 on: June 29, 2013, 07:38:56 PM »
doesn't take long to make it look like 6 months age !
an hour and a half and it's back in bits
http://i1056.photobucket.com/albums/t373/Eddie096/A78ADA92-91AF-4434-A9CD-32DD61389DB3-9738-000011CA048D32B7_zps05c9cd2a.jpg
A little progress
then made some nice gussets....ooooer
http://i1056.photobucket.com/albums/t373/Eddie096/CBB86CB4-F8FE-4E5B-AE91-304B6ED3D908-9738-000011C693F39A7C_zps321ac0af.jpg
A little progress
and welded em in
http://i1056.photobucket.com/albums/t373/Eddie096/65AEE84A-43F2-4BFF-93A5-E930081F61F7-9738-000011C69E04BAE5_zpse4c0d788.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/5BF123EB-68EC-42BB-A3A4-7CAE44B94F55-9738-000011C6AF1518E9_zps6431638b.jpg
A little progress
trikerpete
« Reply #299 on: June 30, 2013, 09:37:16 PM »
Like the tow bar, hope that single mount under front of engine is man enough as it looks to be taking all the weight.
