April 22, 2026, 01:35:56 PM *
Pages: 1 ... 17 18 [19] 20 21 ... 36
Author Topic: A little progress  (Read 160799 times)
steven brock
« Reply #270 on: June 08, 2013, 02:20:39 PM »
That's inspired me to wire mine but I have no clue ..  Huh
« Reply #271 on: June 08, 2013, 08:37:13 PM »
at the point where i need somwhere to mount all these wires 'n' stuff. decided to mount all in the right hand dummy tank so started with a template
http://i1056.photobucket.com/albums/t373/Eddie096/8F0B7324-2398-43DE-AE69-419793EAAD51-5368-0000093AE73AFB0C_zps1cbc53cb.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/D2090A5C-9E9D-41A6-83F9-CEB27D7A394A-5381-0000093C07A67D5E_zpsac1e8bf8.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/Untitled_zpsb2ea8b01.png
A little progress
which turned into this.fab'ed by Alan in aluminium
http://i1056.photobucket.com/albums/t373/Eddie096/E27E25FB-A0C4-4EE0-9815-269B764982B6-6393-00000B66BF6E08C9_zpsea7ae1a1.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/9A75AFD6-70EC-4C3D-9AEC-2CCB93988F95-6393-00000B66EEEE77D0_zps65bc4822.jpg
A little progress
got it mounted only to discover the coil is buggered,oil leaking from where the coil lead plugs in,unusual???
« Reply #272 on: June 08, 2013, 08:42:28 PM »
so moved on to mudguard brackets
http://i1056.photobucket.com/albums/t373/Eddie096/05E9F7CB-94A2-43F2-A60A-729F1B21C297-6393-00000B66CD246100_zpsd6c5898d.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/671B2456-6C4D-4B7C-9E14-F248AEE8CD56-6393-00000B66D43B3915_zps5e8c8bc7.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/6C0635DE-C565-4473-8360-526CBB6EA564-6393-00000B66DB04C7D9_zps991bf66f.jpg
A little progress
mounting bolts welded in to keep the top clean
http://i1056.photobucket.com/albums/t373/Eddie096/6183B47E-7F65-48B5-BE54-7133A020978E-6393-00000B66E7958250_zpse1c288f0.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/1E91BC2B-473F-4B9D-A5AD-5ECD8B11DDCF-6393-00000B67056B9B06_zps756f26fe.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/0BFCA0EF-59B6-4292-B6D9-0412C76EF4D1-6393-00000B670C47223F_zpsa4a367ad.jpg
A little progress
lights mounted front and rear
http://i1056.photobucket.com/albums/t373/Eddie096/7C102F50-34BA-4961-9AFA-F06F14C0626A-6393-00000B671B3D6C43_zpsa90d5894.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/1D82CB68-1898-4154-ABFD-38B59E1D8C80-6393-00000B66F684AB6A_zps2e381bc7.jpg
A little progress
« Reply #273 on: June 08, 2013, 08:46:22 PM »
just do 1 circuit at a time  and you'll soon get there,any question just ask and if all else fail's
i'm only an hour and a half away
« Reply #274 on: June 08, 2013, 09:32:33 PM »
As scannerzer says it's not as difficult as it looks.
Take it one lead at a time. Colour coding or labels at each end is a good idea as is making the leads a bit too long( they can always be shortened later)
My front to rear loom is trailer cable in its cover and most of the rest is made from leads stripped out of the cover and re bundled as required in heat shrink. This gives you seven different colours without having to buy lots of reels.
« Reply #275 on: June 08, 2013, 10:58:28 PM »
Yep i agree  with ON trailer cable is the way to go and if you use the colours as you would on a trailer it will
always make sense if you have a fault down the line
steven brock
« Reply #276 on: June 09, 2013, 07:48:29 AM »
5 or 7 core? Huh
« Reply #277 on: June 09, 2013, 08:45:00 AM »
The trikes looking good, I want that front mudguard Grin
« Reply #278 on: June 09, 2013, 08:47:29 AM »
5 or 7 core? Huh
7 is what i've used i tried to get 4 core but no one locally stock's it anymore, but 7 leaves you room for expansion,extra lights etc or a spare wire should you ever get a break in a wire you can't trace
Thanks Merv,if i don't use it i'll let you know Wink
« Reply #279 on: June 15, 2013, 10:49:23 PM »
got a few hours with the trike today so the wiring continues
got these waterproof connectors from ebay to allow easy removal of some of the parts like mudguards and hand controls
http://i1056.photobucket.com/albums/t373/Eddie096/1280AE3E-96B1-4FFB-83B3-37A3734A7E6F-7596-00000D345837F694_zpsdb90dec9.jpg
A little progress
ran the wiring through the mudgaurd brackets to the front and rear lamps for both protection and tidyness
the holes will get grommets after painting
http://i1056.photobucket.com/albums/t373/Eddie096/1ACBB067-CD7E-474A-95EB-9B8ED7E55F3A-7596-00000D3465192300_zps0dc95e8f.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/EFC5CD8E-F93D-445C-9748-820871B17548-7596-00000D346E85375F_zps1d59b530.jpg
A little progress
never used these type of connector before thay are tyco amp superseal 1.5 so here goes
http://i1056.photobucket.com/albums/t373/Eddie096/235D33B1-2D9F-4400-9D63-F556D2AE9CAE-7596-00000D347B4799BA_zps5b154c6f.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/95B9EFB2-7F1A-4FF7-9789-2C0795A20442-7596-00000D34866055D8_zps69319657.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/67BF70C4-BFE1-4C40-8632-B7B4A77546C8-7596-00000D3492CE901A_zpsff5484b6.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/D577B3B2-D46F-45CE-B8F4-6E60095ADF32-7596-00000D34ABD3DBD1_zpsbade627c.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/507D6470-D8DF-400E-AD7F-0D505D55CD5B-7596-00000D34B5416D9F_zpse803cf17.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/A1FC6E0A-9B89-422F-B0BD-8182E0D9044B-7596-00000D34BF5CADB3_zps916c1970.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/91C7C3B6-B2F0-4D15-8615-3CD1007C6D92-7596-00000D34C7C977C4_zps6e760927.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/E49B93D3-73FA-4A7B-B419-4A48B653A821-7596-00000D34D0197229_zps8f4f80af.jpg
A little progress
spot the mistake (s) Angry Angry
« Reply #280 on: June 15, 2013, 11:03:21 PM »
boy was i cross when i realized that i had forgot to include the wiring for the front side marker in these connections,good job the are reuseable Wink
having refitted the plug with all the wires this time checked continunity from the plug to the ends where the lights connect
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/E22193F1-3BDF-4538-8566-ED37AD4B3D44-7596-00000D34D6BC4645_zps5952a62e.jpg
A little progress
with the brackets fitted
http://i1056.photobucket.com/albums/t373/Eddie096/25A0C6EE-2912-4E28-92E8-FFC22A0774BE-7596-00000D34DEA349CC_zps11d72b7e.jpg
A little progress
and now the other side of the plug on the frame
http://i1056.photobucket.com/albums/t373/Eddie096/10B3FB48-D782-4CEB-BA0B-FD6178770541-7596-00000D34EC91A2E7_zps59d080e3.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/DF0CD478-8983-4E51-977F-B4A7FE3690D2-7596-00000D34F4420434_zps03bfb395.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/3BE1588B-93ED-47C5-A900-63E7D24AFB3C-7596-00000D34FFB529DF_zps370441e2.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/B1442965-2C9E-4307-A21E-54D4DB2840FF-7596-00000D3505EDE4FE_zps4bc7486d.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/09B613D6-F316-40B4-8671-0FEDBB7FDD7E-7596-00000D350CE262C1_zps7ba0e502.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/BB250E00-99AE-4622-A2D8-773151C747F6-7596-00000D35138EC677_zps68a67113.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/1A6486C1-4C4C-4850-A2E0-BD222D6616E5-7596-00000D351ADA98B5_zps0972611e.jpg
A little progress
the extra plug is for the numberplate light and rear fog lamp
the other mistake? well i'm not sure if it is, but for the rest of the connectors i clamped the little yellow gaskets on each wire with the cable strain relief, not sure which is correct Huh
« Last Edit: June 15, 2013, 11:07:27 PM by scannerzer » Logged
« Reply #281 on: June 15, 2013, 11:09:38 PM »
and these arrived today so might get the brakes plumbed up next week
http://i1056.photobucket.com/albums/t373/Eddie096/556B787A-E04E-47C6-9C90-360BC3A76CF8-7596-00000D34E5615634_zps77a4b76d.jpg
A little progress
 Grin Grin Grin
« Reply #282 on: June 16, 2013, 03:17:53 PM »
My, you have been a busy bunny haven't you. Very tidy.
« Reply #283 on: June 18, 2013, 09:33:32 PM »
at last the wiring is finished (i think/hope)
not quite as neet as i would have liked but i'll have a little tidy at final assembly
http://i1056.photobucket.com/albums/t373/Eddie096/D7FCCCE3-5C8F-4974-B1AF-CF0BA560AA21-7633-00000E2840BC6227_zps6d06eda0.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/EEB79E1B-EE82-46E5-B0F9-1F8CF9B5B8BC-7633-00000E28587AED8B_zpsedd874a2.jpg
A little progress
steven brock
« Reply #284 on: June 19, 2013, 12:47:01 AM »
Fantastic  Grin
