November 05, 2025, 01:43:40 AM *
Pages: 1 2 [3] 4 5
Author Topic: My budget build  (Read 17001 times)
« Reply #30 on: August 01, 2011, 07:19:28 PM »
Kev, if you want diagrams for the Haynes arms..........
kevsky
« Reply #31 on: August 01, 2011, 07:37:57 PM »
have got access to the build your own custom car for 1 shilling and 3 pence happenny but it shows the top and bottom arms not using a wishbome type thingamy i.e 4 straight rods instead of 2 on inside and 1 on outside and was just trying to nick skips idea but instead of a square box around the diff was thinking of an 8 sided (don't know the correct name so lets call it it whatagogon)
and piccies are a lot more helpful than lines on a piece of paper
who would have believed that I studed to be a technical draughtsman
« Reply #32 on: August 01, 2011, 07:43:25 PM »
On the bottom arms?
The 3rd rod is angled between the outer ones, I believe this design was for use with sierra hub carriers.
If you want drawings for them........
skiprat
« Reply #33 on: August 01, 2011, 08:17:13 PM »
Yeah i copied the haynes book for the wishbones and uprights. Seemed silly to not take advantage of someone elses work and proven design.
I would redesign the rear cage if i had the gear to get nice tight bends. But i work on the premise that i make things with what tools i have.
I worked out how wide i wanted it to be. Then worked backwards from there.
Bus Boy
« Reply #34 on: August 06, 2011, 10:44:59 AM »
so, are you running shortened drive shafts or are the wishbones longer than the ''book'' specs........also , rear shocks,as per book or special spring rate??........sorry bout all the questions but you've got me finkin'
skiprat
« Reply #35 on: August 07, 2011, 08:34:41 PM »
yes both shafts are shortened, think they are about 450mm each
I used the book wishbones purely because it was easy and local kit car builder had made the jigs to build the arms
then I mounted and made the frame to get the overall width how I wanted it
with the 295 tyres on the back, total max width is 1650mm
Bus Boy
« Reply #36 on: August 08, 2011, 01:13:29 PM »
ah ha, but what about the shock spring rates?
skiprat
« Reply #37 on: August 08, 2011, 03:04:33 PM »
well I bought the shocks with a pair of springs, then made the mounts suit the pondage of the springs LOL
but my rear springs are 200lb each, shocks are AVO adjustable, set fairly hard.
if I keep it then over the winter theres a lot of changes to be made, moving the shocks a bit, seating changing, and probably going to have to move the diff over, I desperately didnt want to, but think Im going to have to.
Bus Boy
« Reply #38 on: August 09, 2011, 01:47:07 AM »
cheers guy Cheesy.....all info goin' into storage ready for future reference! Grin Grin
trikerpete
« Reply #39 on: August 11, 2011, 11:26:03 PM »
the last irs rear end i did on a mates trike used a weld on "casarva" kit and they recommend a pair 900lb springs Roll Eyes
« Reply #40 on: August 11, 2011, 11:29:29 PM »
hey, pete where did you get the kit from ??
 and have you done that there gear linkage yet  Cheesy Cheesy
skiprat
« Reply #41 on: August 22, 2011, 01:27:07 PM »
woohoo finally found an MOT place that will even look at it, the other class 3 places all said no as they dont know what it is LOL
friday at 2 oclock
only thing Im worried about is the rear brakes, new discs and think they need some scrubbing??? but will have a chance to play on the way to the MOT. rear balance is possibly a bit out, unsure how much, one locks, one doesnt
skiprat
« Reply #42 on: August 22, 2011, 01:43:13 PM »
aha thats interesting, just realised that brake imbalance is only a fail on the steered wheels Smiley
so the back end of my trike is safe.
need 25% and 30% braking ability, well the fronts have 12 pistons grabbing at 2 dinner plate sized discs LOL, and they are rock solid so thats the 30%, be interesting to see how the rears do, wish I had some smaller wheels to chuck on to be honest, the height of my tyres wont be helping
« Reply #43 on: August 22, 2011, 08:25:08 PM »
Good luck Skippy.  Wink
trikerpete
« Reply #44 on: August 23, 2011, 03:52:13 PM »
Kits available from Casarva, email them for info at matt@casarva.co.uk be sure to tell them I sent you.
Yes, just done linkage yesterday.
Used a brand new Nissan Bluebird Ball Joint from good old fleabay, only £3.50 inc P+P Smiley
Thanks for the info Smiley
Pages: 1 2 [3] 4 5
