Hi all,
New to the forum and currently building first trike,very close to finishing however need a few pointers on MOT and also a question about the engine missing
So firstly here are my MOT questions
1) Does my trike need to have a reversing light?
2) Does the trike need to have reflectors and lights on the tins?
3) Does my trike need to have tins at all?
4) Does the brake light have to come on when I pull the front brake or only back brake?
5) Does the speedo have to be mounted on the bars or somewhere 'up top'?mine is currently on the frame next to the main engine bay
6) and here's the big one.....it's a reliant rialto engine and I've checked all of the following however it still will not run smooth and coughs and splutters,it's rideable,but only just!ive checked the spark plugs and put new in,the dizzy is perfect,the carb is getting enough fuel and the float works fine,the fuel pipe is not blocked,the ht leads are brand new,I've tried the carb on loads of different settings and pretty much flooded the engine with fuel and still the same.....any ideas would be very very welcome!
Also apologies if any of the above has been covered already but I need definitive answers ASAP
Thanks all! Will post pics soon also
Danny
1) No it is optional
2) No to reflectors, they should be mounted to the rearmost of the vehicle as much as is practicable. You need front position lamps, these can be mounted at the front or can be mounted on the mudguards facing forward. The lamps need to be a maximum 400mm from the outside edge of the vehicle.
3) Yes, construction and use regulations. No for an mot
4) If you can con your MOT station that it is an old build, pre MSVA regs, then front only is fine. MSVA regulations are not retro fit.
5) I would mount it in the direct field of view. (cos you`ll need an MSVA) but as Terry says, as long is one is fitted is good enough for a mot
