May 16, 2026, 02:20:27 AM
Trike Tech
Pedals
Pages:
Topic: Pedals (Read 5202 times)
Re: Pedals
Reply #15 on:
July 15, 2011, 11:50:39 AM »
The Tang also needs to be positioned where it will give maximum amount of travel to the operating rod before the pedal is depressed to far.
This will depend a far bit on your riding position, because your seating position will affect the movement of your foot!
For mid controls i have the arm angled at around 40 - 45 deg, i find then that i can achieve full rod travel before my foot is horizontal. In fact on the Kawasaki, i can lock the brakes up within 10 deg of pedal travel.
Re: Pedals
Reply #16 on:
July 15, 2011, 11:52:28 AM »
Quote from: DIZZY on July 15, 2011, 11:26:17 AM
Thats brill thanks alot for taking the trouble to explin ,it will help a lot
No problem, i got some more pics but Mrs T wants the computer now, so i`ll add them later.
Re: Pedals
Reply #17 on:
July 17, 2011, 10:57:19 AM »
Here you go then, pedals........ Don`t copy and print these, they are not to scale.
If anyone needs proper pics that are to scale, I can add pdf files for downloading
Both pedals are 6:1 ratio and would use a 30mm OD pivot, the holes for the pads, or in this case, toe pegs would be drilled to 6.5mm then tapped to 8mm.
Re: Pedals
Reply #18 on:
July 17, 2011, 09:59:33 PM »
Why don't some of you clever peeps live down here? I want a solution for my touring pegs, at present attached to the engine bars but not really doing it for me any more.
Last Edit: July 18, 2011, 12:45:38 PM by BikerGran
Re: Pedals
Reply #19 on:
July 18, 2011, 09:03:42 AM »
PDF files for download. Make sure your printer settings are not scaled, these need to be printed 1:1 scale. (files carry the MMM watermark)
Pages:
