March 23, 2026, 07:08:55 PM *
Pages: 1 ... 4 5 [6] 7 8 ... 27
Author Topic: Reliant Disc brake conversion  (Read 338992 times)
Hagar
« Reply #75 on: September 28, 2008, 09:19:50 PM »
Evening ,
Are you gonna do a write up on the boat too?  Grin
so many projects so little time  ..   Grin
cheers  ..  Hagar
tony b
« Reply #76 on: September 28, 2008, 10:31:35 PM »
has any one mentioned that you cant use standard wheels once you have changed the drums to disk,you have to get bigger wheels..........shabba.
« Reply #77 on: September 28, 2008, 10:36:31 PM »
Yeah, its touched upon in the original write up that Mr Mankey did
Hagar
« Reply #78 on: September 28, 2008, 10:57:23 PM »
Evening ,
think these will do the job ?
http://img.photobucket.com/albums/v113/codpiece/1fromrear.jpg
cheers  ..  Hagar
Hagar
« Reply #79 on: September 30, 2008, 09:59:46 PM »
Evening , I've not got the calipers through yet , but I've just had a quick offer up of the nova discs    ......  and I've got about 2  1/2" inch clearance all round ....  will this be enough ?   ( she sits on revolution wheels and 275/50R15 tyres ) .
cheers  ..  Hagar
harley gazz
« Reply #80 on: October 01, 2008, 01:46:35 PM »
yall be alreet as long as yer calipers are clear from inside of rim hagar slip disc over studs ,put caliper on offer wheel back on ,but you will need more than two hands to do this  Grin im runnin suzi jeep 15" alloys and discs granada calipers with big tyres an they fit an work like dream  Cool Wink
arc eye tha noo
Hagar
« Reply #81 on: October 01, 2008, 06:55:00 PM »
Evening , cant check till I get the hubs and discs back , I'm using nova discs  and golf calipers ( was told they were off of a 1.8 gti ). Do you think I should invest in some longer studs ? .
cheers  ..  Hagar
« Reply #82 on: October 02, 2008, 09:37:33 PM »
Hiya,
a very quick check of my trike's arse end says the caliper stands about 2 inches up from the edge of the disc. I'm running 15 inch alloys. I used 1 1/4 inch spacers from SpeedShack, (their details are in the Links for Commercial Purposes bit of the forum), to space the wheel away from the disc & caliper to give some extra clearance. The spacers come with stud extensions. Check the thread on my trike frame in General Discussion for photos & descriptions of everything on my trike so far.
bitzman5
« Reply #83 on: October 03, 2008, 10:11:31 PM »
HELP  Wanted can any one send me a paper or cradboard template for the back plate conversion as i dont seem to be able to down load the info thanks in advance
« Reply #84 on: October 03, 2008, 10:27:27 PM »
Sounds like a job for Super TBone!
Hagar
« Reply #85 on: October 06, 2008, 05:28:49 PM »
Evening ,
Downloading and printing it off is the easiest way , what sort of problem do you have with the download ? ..
cheers  ..  Hagar
« Reply #86 on: October 06, 2008, 05:35:17 PM »
I`m on to it boss   Wink
« Reply #87 on: October 06, 2008, 08:43:09 PM »
cheers  ..  Hagar
this is how Andys look with the spacer fitted
« Reply #88 on: October 06, 2008, 08:48:34 PM »
and minus the wheel you can see how high the caliper sits off the disc
Hagar
« Reply #89 on: October 12, 2008, 01:05:22 PM »
Afternoon , thanks tbone the pictures help ..   still collecting bits , can anyone recommend a small'ish handbrake lever that'll work with the Golf mk2/3  calipers  or is it best to stick with a Golf one ..
cheers  .. Hagar
