March 19, 2026, 08:45:49 PM *
Author Topic: My Trike  (Read 7216 times)
Strangely Made
« on: June 27, 2010, 02:54:14 PM »
Thought I'd put up some pictures of my trike build.
Originally got the trike in 99, when it looked like this
http://i25.photobucket.com/albums/c53/strangely-made/Image2-1.jpg
My Trike
Bought it off Bowser, who is an old mate of my wife. Had a 1300tp beetle engine on it and was pretty nippy. Rode it around like that for a while until the engine broke. So sourced a new engine, this time a 1600TP VW. Unfortunately just before I was going to put the engine in I was diagnosed with epilepsy and put on medication. Also had to surrender my license  Sad.
So it sat in the garage for a couple of years while I got used to the medication, but as things do, plans changed and it went from a engine swap to a full rebuild.
So in these are a few of the build pictures, you might notice that ideas change as the build goes along.
New engine in, and a roll cage sitting on the frame
http://i25.photobucket.com/albums/c53/strangely-made/trike2.jpg
My Trike
An idea I tried out for the front end
http://i25.photobucket.com/albums/c53/strangely-made/trike4.jpg
My Trike
Rear view with the roll cage partly fitted
http://i25.photobucket.com/albums/c53/strangely-made/trikeframe.jpg
My Trike
Strangely Made
« Reply #1 on: June 27, 2010, 03:00:54 PM »
I'd also joined the Baja club, so decided to modify the trike so I could play with the club at our permanent play ground at Santa Pod
Raising the rear
http://i25.photobucket.com/albums/c53/strangely-made/trikeduring.jpg
My Trike
Bought some new forks, came from a chop and the guy told me they were from a KTM, turns out they are actually off a 91 Cr250 so even better.
http://i25.photobucket.com/albums/c53/strangely-made/aaaaaaaaatrikeforks.jpg
My Trike
And fitted to the trike
http://i25.photobucket.com/albums/c53/strangely-made/Trikey3.jpg
My Trike
Fitted some 24" apes, just because  Grin
http://i25.photobucket.com/albums/c53/strangely-made/Trikey4.jpg
My Trike
And a stock airbox
http://i25.photobucket.com/albums/c53/strangely-made/Trikey5.jpg
My Trike
Strangely Made
« Reply #2 on: June 27, 2010, 03:09:07 PM »
The rear wheels were a bit small,
http://i25.photobucket.com/albums/c53/strangely-made/trikewheel1.jpg
My Trike
So bough a pair of 15" weller 8 spokes off a club member. Much better, and give me about 14" ground clearance
http://i25.photobucket.com/albums/c53/strangely-made/trikewheel3.jpg
My Trike
Tried out a headlight mount I made, not pretty, but was bloody strong, could lift the whole trike with it.
http://i25.photobucket.com/albums/c53/strangely-made/mudguard4.jpg
My Trike
It's not staying though, got some smart new lights custom made by a mate, but they'll be the last things to go on.
That's about it, still it's a start, and things will change, as I carry on with the build. Got till Jan 7th 2011 to complete it, because that's when I get my license back this time, had to take another year off driving because of another medication change due to the tablets not working anymore.
Richie 66
« Reply #3 on: June 27, 2010, 04:00:59 PM »
Oh my gawd fancy bumping into you again  Cheesy some nice pics there fella , keep 'em coming.
bitzman5
« Reply #4 on: June 27, 2010, 06:00:33 PM »
Nice little build up your wheels are a bit of camber try shifting it by turning the rear arms a couple of splineshad to do that on my Albar beach buggy
« Last Edit: June 28, 2010, 12:50:42 AM by bitzman5 » Logged
« Reply #5 on: June 27, 2010, 06:48:02 PM »
You started building it in black & white then.
I don't think we've had a proper off-road trike here before. Interesting.
Is there a course at the Pod then? Only been there a couple of times, but never strayed far from the drag track.
« Last Edit: June 29, 2010, 08:57:51 AM by Manky Monkey » Logged
Strangely Made
« Reply #6 on: June 27, 2010, 08:25:56 PM »
Nice little build up your wheels are a bit of camber try shifting it by turning the rear arms a couple of splineshad to do that on my baja beach buggy
Yep, bit of camber there, partly because I've put about an extra 16° 20' (roughly) in by turning the spring plates round two outer splines, standard practise in Baja's. It'll even out enough with the engine, seats and fuel tank in.
Not sure I've seen another one in the UK either, one if the States I know but more of a toy that one. This will be my daily.
Yep, the Baja club has got one permanently there now, also building one at the site for the Bristol VW shows, and always do loads of Green Lanes when we get together.
I've been talking to the organisers of the Elephant at the Nurburgring and they're letting me play on the off road track there in 2012 Smiley
it's going to get better, but have to get it on the road again first, then the fun modifications can start. You know, IRS, 3X3's, secondary torsion bars, that sort of thing.
bitzman5
« Reply #7 on: June 27, 2010, 10:58:07 PM »
Hi S/M YES THAT SOUNDS ABOUT RIGHT BY SAYING MINE WAS A ALBAR BUGGY WAS NOT THE SAME AS THE BAJA. MINE WAS A SWISS MADE ONE I BELIVE HAD ALBAR EMBROSSED IN THE FIBERGLASS JUST UNDER THE WINDSCREEN AND HAD A TYPE OF PERISCOPE AT THE REAR ABOVE THE CARBS THY WERE EXPORTED TO THE SAND DUNIE OF THE ARABS A FEW CAME BACKOR NEVER WENT TWO YEARS OF SHOWS AND TILL 4 YEARS AGO SINCE I STOPED SHOWING MY KITCARS IV NEVER SEEN ANOUTHER LIKE IT
« Last Edit: June 28, 2010, 12:49:58 AM by bitzman5 » Logged
Hagar
« Reply #8 on: June 28, 2010, 04:31:45 PM »
You probably should sort out the exhaust  if you need to carry a gas mask  .....   Grin
  ..  Hagar  ..   Grin
Strangely Made
« Reply #9 on: June 28, 2010, 10:00:50 PM »
The trike exhaust is fine, my exhaust on the other hand..............makes my eyes bleed sometimes Grin
Strangely Made
« Reply #10 on: July 07, 2010, 10:25:36 PM »
Look what I got today
http://i25.photobucket.com/albums/c53/strangely-made/plastics2.jpg
My Trike
Not very exciting, but they are from a cr ten years newer than the cr that the forks are from, so will need a fair bit of modding to make fit. Plonked them on the forks today, just to see how they look and there is a good weekends work there to sort them out.
http://i25.photobucket.com/albums/c53/strangely-made/plastics.jpg
My Trike
http://i25.photobucket.com/albums/c53/strangely-made/plastics1.jpg
My Trike
Hopefully should help protect the forks and seals a bit green laning and playing off road.
Strangely Made
« Reply #11 on: August 05, 2010, 11:50:33 PM »
HaHa, look what I bought today http://i25.photobucket.com/albums/c53/strangely-made/tyres2.jpg
My Trike
31x10.50x15 MTs, should be fun watched Colin round the garage squeeze them onto 7" wide rims Smiley Then, I'll have to paint the wheels. And now that the harvest is almost over, I'll actually be able to get out to the shed and do some more bodgeing building.
« Last Edit: August 05, 2010, 11:52:18 PM by Strangely Made » Logged
ByzMax
Choppit
« Reply #12 on: August 06, 2010, 06:51:47 AM »
Nice one Mr Strangely.
What are you going to do about uprating the Brakes?  I suspect with those wheels/Tyres you will need too increase the stopping power a wee bit due to the leverage increase
http://www.choppit.co.uk
Strangely Made
« Reply #13 on: August 06, 2010, 10:31:51 AM »
I'm going to change the slave cylinders in the drums from the stock rear ones to front ones. They're larger so should work fine, or at least that's the theory.
ByzMax
Choppit
« Reply #14 on: August 06, 2010, 11:44:14 AM »
I put 67 type 3 (I think) on the pheonix (22mm) as no mods are required and the bleed screw end up above the pipe like it should. Worked ok but those tyres look a tad bigger.  Wink
