Really fallen out of love with this lately.
Seems like every time I think it's finally almost done, it takes several very large steps backwards & I have to throw yet another bucketful of money at it. Because it's in a different garage to my truck, on the other side of town, it's been easy to just ignore it & concentrate on the truck instead. I need to crack on with it though or it'll just languish there for ever.
Didn't have enough time after work today to get anything achieved in the truck garage, so I've been sat, taking a long look at the bike. I think I need to take the plunge & pull it apart -when it's in one piece I'm loathe to start on it.
The righthand engine casing needs to come off, (draining just the oil that it loses when it's on the sidestand -not really worth changing the sump filter yet), then I can tackle the clutch again. With all new parts, it can't be a big problem -I'm not putting the casing back on till it's fixed.
I've got new alternator brushes so can take the other casing off & fit those, but can't run the engine to check the output again without charging the battery first. That involves taking the battery out to charge at home, (no power supply in the garage). If I'm doing that, I may as well take the box out & modify the front, for easier access in future.
I've ordered a couple of lengths of the smallest bore perforated tube I could find & some washers to make end collars with, so will have a go at the exhaust baffles when it arrives. The pipes are 41mm I/d & the tube's about 32mm.
I bought an aftermarket Harley style brake cylinder, intending to take the back brake set-up apart & simplify it, but looking at it, it'll be a major job to do -& the new cylinder won't fit anywhere I thought it might -so that's going in the spares box & I'll stick with the set-up I've got.
It'll probably be the weekend now before I get enough daylight to make a start, but the sooner I do, the sooner it'll be finally finished -please God, no more set backs.
