April 16, 2026, 08:18:36 AM *
Author Topic: steering info needed.  (Read 13892 times)
« on: March 22, 2010, 06:12:00 PM »
Hey oh Manky one  Cheesy Cheesy can you remind me what car the steering joints are off please?? I know mine are from Pop brown but didn't you say they are the same as a Huh? also where did you get your splined shafts from please as I'm in need of one for my steering and I can't afford PB's prices at the moment  Cry Cry btw I don't need anymore joints just the splined shafty bits  Grin Grin Grin
lunatic
« Reply #1 on: March 22, 2010, 08:22:03 PM »
They are a mix of pop browns, dunno what part number, and some range rover ones. I would just use rangie ones when I next do it, they are big an chunky. What about Land rover ones? Might be the same thing?
« Reply #2 on: March 22, 2010, 10:24:00 PM »
Yup, Mr L's right. One of the knuckle joints came from Chris at Pop Browns -someone identified it as an early Ford Escort one. The other was donated by one of Loony's mates & is a Rangie one. The splined shaft is Range Rover too I think. My memory's lousy but I would've mentioned it in my Pop build thread.
« Reply #3 on: March 23, 2010, 04:21:32 PM »
cheers guys, so does the RR splined section fit the Ford knuckle joint  Huh Huh Huh
« Reply #4 on: March 23, 2010, 04:33:40 PM »
Check back in my Pop build thread Shaun -my memory really is that bad, but we didn't re-spline anything, so it must've fitted.
« Reply #5 on: March 23, 2010, 04:36:28 PM »
I had a look yesterday, have you seen how many pages  Shocked Shocked Shocked Shocked I'll take another look mate  Grin Grin
« Reply #6 on: March 23, 2010, 04:41:39 PM »
 Grin At least you only have to read them. I have to write them too.  Tongue
Once the Pop's on the road, I'm going to collate the forum stuff into half a dozen chapters, (chassis, bodywork, brakes, steering etc), & post it on the main site. Hardly a definitive guide to building a rod, but it should give readers some idea of what's involved, warts 'n' all.
« Reply #7 on: March 23, 2010, 04:55:21 PM »
found it  Cheesy Cheesy Cheesy
" So. The modified Pop steering box has a splined end welded onto it's shaft, to hook up to a universal joint bought new from "Pop Browns". On the other side of the joint is another splined section welded into the end of a Range Rover shaft. That pushes into a Range Rover universal joint. On the other side of that is the cut off splined bit of the Rover shaft, welded into the bottom of the Moggy Minor column. Easy.
The Godawful lumpy welds on the ends of the shafts were smoothed off with a sanding disc on the grinder, then I drilled through the joints & pinned them with 4mm engineers dowels, welded at either end.
« Reply #8 on: March 23, 2010, 05:40:13 PM »
There ya go. That bloke obviously knows what he's talking about.  Tongue
« Reply #9 on: March 24, 2010, 03:53:50 PM »
obviously  Roll Eyes Roll Eyes Roll Eyes where would one get those 4mm engineers dowels from oh man who knows stuff  Huh Huh Kiss
« Reply #10 on: March 24, 2010, 10:49:44 PM »
Well, if it were me, I'd go to my local tool shop -a proper tool shop, not B & Q.  Smiley
Got one near you? Or want me to pick a length up from my local?
« Reply #11 on: March 25, 2010, 07:21:52 PM »
yes please mate  Kiss Kiss Kiss all crap around here  Roll Eyes Roll Eyes Roll Eyes
« Reply #12 on: March 25, 2010, 09:45:06 PM »
Nae problem matey.
« Reply #13 on: March 27, 2010, 02:07:53 PM »
Two 300mm long lengths of 5mm bright steel on their way to you Shaun. Ten quid.
« Reply #14 on: March 27, 2010, 04:07:02 PM »
cheers mate  Kiss Kiss cheque or paypal or casherooney  Huh
