April 13, 2026, 01:03:41 PM *
Pages: 1 [2] 3
Author Topic: neck ache!  (Read 10560 times)
madron
« Reply #15 on: February 08, 2010, 10:53:08 PM »
for about £6 ya can buy anti spatter spray stops wire  stickin to nozzles save ya time n money
« Reply #16 on: February 09, 2010, 10:07:15 AM »
Yeah, seen it, even used it a couple of times. Never gotten round to buying any. I'm a lazy Monkey.
cunningplan
« Reply #17 on: February 09, 2010, 06:46:11 PM »
A place I used to weld for had tins of what looks like wax, every so often I just dipped the nozzle in and I had no problems
gazzagood
« Reply #18 on: February 09, 2010, 08:46:12 PM »
that will be tip dip i use it all the time and anti spatter great stuff
« Last Edit: February 10, 2010, 01:29:50 PM by gazzagood » Logged
PLEASE
« Reply #19 on: February 09, 2010, 11:50:19 PM »
Like this.
http://cgi.ebay.co.uk/MIG-WELDING-TORCH-TIP-DIP-ANTI-SPATTER-PASTE-500g-TIN_W0QQitemZ310190100601QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item4838c55079
« Reply #20 on: February 10, 2010, 12:07:34 AM »
Brilliant! Never heard of that before.
cunningplan
« Reply #21 on: February 10, 2010, 02:27:54 AM »
Thats the stuff, it was better when the nossle was hot, dip it in, give it couple of shakes and start welding again.
« Reply #22 on: February 11, 2010, 05:34:34 PM »
So thats not how to break `em  Roll Eyes.
And now back to how to make one......
First a slight problem involving camera batteries, so we pick up visualy with me having drilled the now tube out to 4.5mm to a depth of 8mm. This second drilling makes the hole 0.5mm bigger and will be about right to tap to a 5mm thread, so thats what i did and then screwed a tip in the end.
« Reply #23 on: February 11, 2010, 05:41:48 PM »
Did you spot the 8mm nut screwed on the tube? That`s there because i want to remove some of the thread at the front of the tube, unscrewing the nut when i`ve done will re-cut the start of the thread.
Now, i`ve mounted the tube in my lathe, this is not important, all i need is a way of spinning the tube, a drill, mounted in a vice would do just as well. Starting with a file, i carefully removed most of the unwanted thread section, by moving the file along as the tube was spinning.
« Reply #24 on: February 11, 2010, 05:43:31 PM »
Then it can be finished off by useing different grades of wet n dry paper.
« Reply #25 on: February 11, 2010, 05:48:42 PM »
And after a while you should be able to get it nice and smooth, you dont have to do this, i cant see why leaving it fully threaded would effect how it works, but its up to you.
« Reply #26 on: February 11, 2010, 05:52:43 PM »
Next job is to cross drill it, this allows your shielding gas into the shroud and towards the tip. In my `pattern`, the holes are 1.5mm and located 12mm from the end of the tube, so this is where i drilled them.
« Reply #27 on: February 11, 2010, 05:57:25 PM »
So now i have this......
« Reply #28 on: February 11, 2010, 06:02:23 PM »
all thats left to do now is put a bend into it, but it got to cold in the shed so i`ll do that tomorrow  Roll Eyes.
Cost of buying a new swan neck.....£11.00
Cost of a bit of brass bar ...............£1.50
Cost of fixing a machine with parts you`ve manufactured yourself..........priceless  Grin Grin
« Reply #29 on: February 11, 2010, 08:20:31 PM »
Ooh, I do hate talented people!
Pages: 1 [2] 3
