April 13, 2026, 10:28:26 AM *
Pages: [1] 2 3
Author Topic: neck ache!  (Read 10522 times)
« on: February 07, 2010, 06:00:19 PM »
Hopefully most of you will know what this is? It`s a swan neck from what they term as a "hobby" welder.
Now i`m not saying i get through a lot of these but i have just broke my second one by welding the wire to the tip and trying to remove the tip.
« Reply #1 on: February 07, 2010, 06:05:40 PM »
If you ever need to replace one, it`ll cost you over a tenner, i know cos i bought one last week.
Lets see what you get for your money, a piece of brass tube with a couple of threads in, some holes and a rubber sleeve, HMMM think we can make one?
First thing we need then is the raw material, 8mm brass bar, this will cost you that same ten pound note but for that you get a metre of the stuff, enough to make 6 necks!
« Reply #2 on: February 07, 2010, 06:07:31 PM »
Measure the length of your old swan neck, should be around 140mm, and cut the brass rod to length.
« Reply #3 on: February 07, 2010, 06:18:02 PM »
Tricky part next, you need to drill a 4mm hole through the length of the bar. This is the part that had me stumped for a bit, but after seeking advice (cheers Doc), about the only way to do this is to drill down one end, then flip it over and drill down the other to meet in the middle.
Ordinary drill bits are around 75mm long (this is what i used)  but long series bits are available and would be better.  Wink
Ok OK, it did take me 3 attempts before i got this right, the drill bit had a habit of wandering off centre and out the side of the bar. SLOW and STEADY is the way to do it.
« Reply #4 on: February 07, 2010, 06:25:58 PM »
get that bloody lathe running far better for this kind of job.
Oh by the way I made a brass tube up for you.
Will you be going to Wootten Bassett by any chance?
« Reply #5 on: February 07, 2010, 06:28:05 PM »
With the hole drilled, the next job is to thread one end, useing an 8mm die to a depth of 30mm.
« Reply #6 on: February 07, 2010, 06:31:23 PM »
Now you tell me! all afternoon i been on this  Grin.
I`m working that weekend, i think my first outing is the Monkey Nuts run in april?
As for the Lathe, i have a tailstock chuck but no key  Roll Eyes, and i still need to get around to paying you a visit!
« Last Edit: February 07, 2010, 06:45:18 PM by tbone » Logged
« Reply #7 on: February 07, 2010, 06:33:24 PM »
So now i `have something that looks like this... well actualy i have this....... Grin
« Reply #8 on: February 07, 2010, 06:41:12 PM »
Almost there now.
The welding tip needs to screw in the end, and i need to cross drill the gas holes and then pretty it up before bending to shape, but time caught up with me, so more on this later.
« Reply #9 on: February 07, 2010, 06:45:58 PM »
Wouldn't the easier option be not to weld the tip to the wire!?!?!?!?! Cheesy Cheesy Cheesy Cheesy
« Reply #10 on: February 07, 2010, 06:48:27 PM »
Yeah yeah yeah, you`ll see, you`ve got all this to come  Grin Grin
andbolt0
« Reply #11 on: February 07, 2010, 09:38:07 PM »
when setin up set the wire speed slightly faster and hold the torch a bit further awayalso anti spatter spray into the shroud  helps andy
« Reply #12 on: February 08, 2010, 12:01:17 AM »
Yeah, weld spatter up me nozzle's my biggest problem.
Hagar
« Reply #13 on: February 08, 2010, 12:08:01 AM »
Todays Top Tip   ......  Never whipe your nozzle on their curtains  ......   Grin
  ..  Hagar  ..   Grin
« Reply #14 on: February 08, 2010, 09:21:53 AM »
I use my sleeve, Grin
Pages: [1] 2 3
