February 19, 2026, 04:09:32 PM *
Author Topic: reliant info question  (Read 2812 times)
rockstar
« on: October 20, 2009, 08:07:11 PM »
hello fellow super inteligent monkeys today i read in 100% biker that yellow top enginend reliants have a higher ratio back axle in them and that a large increase in wheel size could adversely affect engine performance as i am intending to run 18 inch wheels with hopefully 60 series tyres would this be a large problem or would you advise finding a low ratio axle  Huh Huh Huh Huh Huh Roll Eyes Grin
if you dont know you should try coz if you dont try you wont know
« Reply #1 on: October 20, 2009, 10:07:54 PM »
Intelligent Monkeys? Counts me out.  Tongue
Plasticpig
« Reply #2 on: October 21, 2009, 01:07:26 PM »
I thought you were the one with the typewriter?
rockstar
« Reply #3 on: October 21, 2009, 04:33:32 PM »
cheers fellas i take it you dont know then Undecided
toad
« Reply #4 on: October 21, 2009, 05:01:42 PM »
yep it will affect performance i reckon your better off with a van or regal axle the later preferably as they ran 13in wheels which would be better suited to the wheels your going to use Wink
rockstar
« Reply #5 on: October 23, 2009, 05:44:46 PM »
hi toad thanks for info,do  you u know if there is any way to identify them once they are out of the body Huh Embarrassed
« Reply #6 on: October 23, 2009, 06:12:19 PM »
Axle ratio..... turns on the diff input shaft to turns at the hub.....http://www.mankymonkeymotors.co.uk/Tech/diff%20ratios/Reliant_axle_info.html
« Last Edit: October 23, 2009, 06:14:18 PM by tbone » Logged
rockstar
« Reply #7 on: October 23, 2009, 06:43:08 PM »
thanks tbone will check it out  Wink
« Reply #8 on: October 26, 2009, 01:31:45 PM »
Err, I thought yellow top was on the high comp engines. I have 2 with yellow tops and they are both high comp, could be coincidence though.
« Reply #9 on: October 26, 2009, 05:53:35 PM »
Yep original yellow tops are higher compression.
