February 19, 2026, 04:08:48 PM
Trike Tech
reliant info question
Topic: reliant info question (Read 2810 times)
rockstar
October 20, 2009, 08:07:11 PM »
hello fellow super inteligent monkeys today i read in 100% biker that yellow top enginend reliants have a higher ratio back axle in them and that a large increase in wheel size could adversely affect engine performance as i am intending to run 18 inch wheels with hopefully 60 series tyres would this be a large problem or would you advise finding a low ratio axle
if you dont know you should try coz if you dont try you wont know
Re: reliant info question
October 20, 2009, 10:07:54 PM »
Intelligent Monkeys? Counts me out.
Plasticpig
October 21, 2009, 01:07:26 PM »
Quote from: Manky Monkey on October 20, 2009, 10:07:54 PM
I thought you were the one with the typewriter?
rockstar
October 21, 2009, 04:33:32 PM »
cheers fellas i take it you dont know then
toad
October 21, 2009, 05:01:42 PM »
Quote from: rockstar on October 21, 2009, 04:33:32 PM
yep it will affect performance i reckon your better off with a van or regal axle the later preferably as they ran 13in wheels which would be better suited to the wheels your going to use
rockstar
October 23, 2009, 05:44:46 PM »
hi toad thanks for info,do you u know if there is any way to identify them once they are out of the body
Reply #6 on:
October 23, 2009, 06:12:19 PM »
Axle ratio..... turns on the diff input shaft to turns at the hub.....
http://www.mankymonkeymotors.co.uk/Tech/diff%20ratios/Reliant_axle_info.html
Last Edit: October 23, 2009, 06:14:18 PM by tbone
rockstar
Reply #7 on:
October 23, 2009, 06:43:08 PM »
thanks tbone will check it out
nabsim
Reply #8 on:
October 26, 2009, 01:31:45 PM »
Err, I thought yellow top was on the high comp engines. I have 2 with yellow tops and they are both high comp, could be coincidence though.
BTW-UK forum
BTW-Area51
Reply #9 on:
October 26, 2009, 05:53:35 PM »
Yep original yellow tops are higher compression.
