February 19, 2026, 11:01:42 AM *
Author Topic: caliper rubber seals+cables  (Read 2235 times)
DIZZY
Ride it like you want it
« on: October 18, 2009, 08:17:55 PM »
Can any one tell me a place to get new seals/rubber gaiters for caliper pistons golf mk2 rears as ive been cleanin up an old set today and ruined the gaiters takin out the pistons.
Also,when i get to it ,should i use full size original golf handbrake cables or some thin else?
cheers Dizzy
Dizzy
gazzagood
« Reply #1 on: October 18, 2009, 08:26:16 PM »
i got a recon kit from bigred i think there in the commercial link
PLEASE
« Reply #2 on: October 18, 2009, 08:34:59 PM »
Speedycables are also listed in the links section, Mr M uses them to make up shorter versions of the golf cables. Depending on where your mounting the lever, you may find the O.E. cables to long.
DIZZY
« Reply #3 on: October 18, 2009, 08:37:48 PM »
ok thanks for the help ill make some phone calls ,order some seals
Dizzy
Dizzy
« Reply #4 on: October 21, 2009, 07:16:37 PM »
Im using inner and outer cables from Vehicle Wiring Products,and making up my own cable stops at caliper end and h/brake end.As Gazza said ,Big Red for the rest.
DIZZY
« Reply #5 on: October 22, 2009, 12:39:11 AM »
Cheers Rod it all helps.
Dizzy
Dizzy
