February 19, 2026, 11:04:19 AM
Trike Tech
caliper rubber seals+cables
Topic: caliper rubber seals+cables (Read 2238 times)
DIZZY
Ride it like you want it
October 18, 2009, 08:17:55 PM »
Can any one tell me a place to get new seals/rubber gaiters for caliper pistons golf mk2 rears as ive been cleanin up an old set today and ruined the gaiters takin out the pistons.
Also,when i get to it ,should i use full size original golf handbrake cables or some thin else?
cheers Dizzy
Dizzy
gazzagood
Re: caliper rubber seals+cables
October 18, 2009, 08:26:16 PM »
i got a recon kit from bigred i think there in the commercial link
PLEASE
October 18, 2009, 08:34:59 PM »
Speedycables are also listed in the links section, Mr M uses them to make up shorter versions of the golf cables. Depending on where your mounting the lever, you may find the O.E. cables to long.
DIZZY
October 18, 2009, 08:37:48 PM »
ok thanks for the help ill make some phone calls ,order some seals
Dizzy
Dizzy
October 21, 2009, 07:16:37 PM »
Im using inner and outer cables from Vehicle Wiring Products,and making up my own cable stops at caliper end and h/brake end.As Gazza said ,Big Red for the rest.
DIZZY
October 22, 2009, 12:39:11 AM »
Cheers Rod it all helps.
Dizzy
Dizzy
