February 19, 2026, 02:46:23 PM *
Author Topic: AXLE ROTATION WRONG? PLEASE HELP.......  (Read 5961 times)
midlifecrisis
« on: October 13, 2009, 02:16:48 PM »
HOUSTON WE HAVE A PROBLEM, I am building a trike based on a Kwak gt550 engine however today i have turned the engine over to start it and the drive shaft is rotating in the opposite direction to the axle. I thought it was a robin axle but after looking in a haynes manual it looks like it could be from a kitten. Do I have to replace it or can i close the little breather hole in the tube and use it upside down, Please help me. Thought i was losing it when i saw it going the wrog way.....he he. Andy.
« Reply #1 on: October 13, 2009, 02:26:44 PM »
Hiya Andy.
Don't worry mate.  Grin  You're not the first one who's done it. I did the same on my first ever trike. Didn't even occur to me to check it.
Yup, you can just flip the axle upside down. Obviously you'll need to blank the breather hole, preferably by welding it up, but if you can plug it with a thread cut into the tube & a small bolt & sealing washer that'll be fine. Even Araldite would do at a pinch though it might well drop out again at some point.
Then just drill a new small breather hole on the top of the flipped over axle.
If you've shortened one axle tube to line the prop up with the bike engine you should be able to swap the gears inside the diff housing around the other way, though I've never tried it myself.
Let us know how you get on please.  Wink
midlifecrisis
« Reply #2 on: October 13, 2009, 02:33:54 PM »
Hi Manky, thanks so much for that info. That will make life so much simpler knowing I can just flip it over. You've made my day. Thanks again, Andy.
« Last Edit: October 13, 2009, 02:41:58 PM by Manky Monkey » Logged
« Reply #3 on: October 13, 2009, 02:40:49 PM »
Tis what we're here for.  Wink
If you're using the original Reliant drum brakes they'll obviously be upside down too. Not sure how that'll affect braking or routing of handbrake cables etc -not a problem if you go for the disc brake conversion of course.
Bobbi, ("BikerGran"), rides a GT550 trike & might well be able to help you with advice or even just photos of her set-up. Her trike, "Gertie", is featured in the Motors, 3 wheels section of the main site.
Gertie
« Reply #4 on: October 14, 2009, 07:31:45 PM »
Willing to answer anything I can but I didn't do the conversion myself.  There are some phots of the set-up on Photobucket Clicky Here
madron
« Reply #5 on: October 14, 2009, 09:03:45 PM »
ha ha first one i built let clutch out to try with no brakes went straight thru me shed lesson learnt just turn it over
« Reply #6 on: October 14, 2009, 09:37:17 PM »
Hi split the axle casing turn the crown wheel over so it sits under the pinion wheel .bolt back together.this way you don't have to alther the brake set up
cunningplan
« Reply #7 on: October 15, 2009, 05:52:05 PM »
I dont know, but cant you just unbolt the backing plates and turn them around , or swap them side to side??
« Reply #8 on: October 15, 2009, 07:41:32 PM »
The rear brakes are single leading shoe, so it makes no differance which way round you fit the backplates! Morrag
cunningplan
« Reply #9 on: October 15, 2009, 08:13:31 PM »
I agree, but what I meant was, that the slave cylinder should sit the right way up or it would be hard to bleed, so spinning the back plate around, it would sit the right way up, but would with the handrake lever would be at the back (Hence swapping them side to side if that was a problem)
http://i267.photobucket.com/albums/ii305/rickyzetec-s/P2040014.jpg
« Reply #10 on: October 15, 2009, 08:30:46 PM »
well  do you know something Grin Grin Grin Grin ,,,,,,,,,,,,, i think i,ve seen that somewhere  Grin Grin pmsl
cunningplan
« Reply #11 on: October 15, 2009, 08:40:05 PM »
Should be on the street by now  Roll Eyes Wink Grin
« Reply #12 on: October 15, 2009, 08:50:00 PM »
seen her today a little rusty in the shed,,,,,,,,,,,,,,,,so took pity on her and made a start again not happy with the headstock bearings so looking for different one,s
« Reply #13 on: October 15, 2009, 10:40:06 PM »
Hand brake position will remain as is, and the small difference in slave cylinder position will have little or no effect on bleeding the system, Morrag
peanut
« Reply #14 on: October 22, 2009, 08:58:59 PM »
there are two types of SLS brakes on Reliant axles. One uses a fixed slave with two pistons and the other has a sliding slave. The sliding type don't work well backwards, ie upside down. If you flip the axle you should also re-drill the drain/feed hole for the nose bearing. On balance it's easier to flip the diff and leave the casing alone. I've done this and hope to god it works!.
