April 08, 2026, 03:46:49 PM *
Pages: 1 ... 27 28 [29] 30 31 ... 36
Author Topic: The Cunning Coupe  (Read 167000 times)
cunningplan
« Reply #420 on: March 26, 2012, 07:13:06 PM »
Sounds real nice that Tony,Looks good to.
When finished yesterday, I just stuck it back on the trailer uncovered and thats how it still is until after work today. So if you want to pop down somtime today, your welcome  Wink
Sorry Tony,Just read this.
To late, it all covered up now  Roll Eyes
cunningplan
« Reply #421 on: March 27, 2012, 10:03:45 PM »
As you can see by my other posting, its all coming together and even managed to drive it for a few yards back and for.
It was the normal  early start Sat morning getting to Steve's around 9, the first thing was to write on the white board what was to do on the weekend.
The first job was to finish the fuel tank and plumb it in. The second part was taken care again by Fay at Speedflow. I liked the look or the rubber type fuel pipe and had this and the fittings to suit. The weld in tank fitting are a larger size that I need, but with the extra fitting at the back are there so fuel injection can be fitted in the future.
I made the rear of the tank (Which Steve calls a Womble face) I had made a template the last time I was down, it took some time but I managed to get it to fit. This was fitted until I fitted the breather and filler cap (Which is turned this was to mimic the one on Chicken Coupe)
http://www.cunningplan.net/fueltank17.jpg
The Cunning Coupe
http://www.cunningplan.net/fueltank19.jpg
The Cunning Coupe
The back was not welded on until some baffles were fitted
http://www.cunningplan.net/fueltank21.jpg
The Cunning Coupe
http://www.cunningplan.net/fueltank22.jpg
The Cunning Coupe
http://www.cunningplan.net/fueltank24.jpg
The Cunning Coupe
http://www.cunningplan.net/fueltank25.jpg
The Cunning Coupe
http://www.cunningplan.net/fueltank28.jpg
The Cunning Coupe
http://www.cunningplan.net/fueltank29.jpg
The Cunning Coupe
http://www.cunningplan.net/fueltank31.jpg
The Cunning Coupe
While Steve was welding this up, I started on the top cover, I had to drill out the holes for the body mounts, (These will be slotted so I wont have to take the mounts off to remove it.) and make the windscreen.
I started by cutting it oversize then folding it to shape. Once I was happy, I cut it to shape and riveted on.
http://www.cunningplan.net/screen1.jpg
The Cunning Coupe
http://www.cunningplan.net/screen3.jpg
The Cunning Coupe
http://www.cunningplan.net/screen5.jpg
The Cunning Coupe
You would not believe how long just these two items took, so after checking the tank for leaks and making the straps, it was time to put some fuel in and adjust the timing, at the moment its set at 34 (My Chrysler was set at 38)
Then it was time to take a drive, all I can say is " it went and it stopped"
Its going to be after Easter before my next trip, theres not much to do but make a coupe of side panels, a dash to fit the idiot lights and finding where to put the chute pull and cable.
« Reply #422 on: March 27, 2012, 11:33:35 PM »
A beautiful, professional job Tony.
« Reply #423 on: March 28, 2012, 03:15:12 PM »
Does what it's sposed to do then - good stuff!
cunningplan
« Reply #424 on: April 30, 2012, 09:50:07 PM »
While at my last trip to the shed, I have been looking at the car and mainly the front end and the ground clearance.
It was hard to see, but both the top and bottom rails ran up to the front axle and made the car so it looked like it was sagging in the middle from the side. The car had 2 1/2 in clearance but this was a pain more so at my garage as we had to lift the front end to get the car into and out of the MOT bay which has a very small ramp.
So I asked Steve to order up some more CDS for this weekend and make up a set of new top rails.
We put the car into the shed and about 1/2 hour later the engine and box were out and all the side and top panels removed. We set out the chassis on the floor with a new ride height of 3" and with the front wheels sitting on the floor (They were off a inch before I cut the tube) and cut out the old top rail. I did this by cutting each side of all the uprights, down the sloping join at the rear (Drilling out the rosette welds) and cutting halfway alongside where the tank sits.
While I trimmed off all the uprights Steve machined 6" connectors for the front. We bent up the new tubes and fitted them into the rear tubes. We marked them at the front and cut them to size. The hardest thing was to get the inner tube in the right place, I did this by marking the centre and then drilled little dimples along one side, I pushed the tubes into the front part then using a screwdriver slid them into place through the rosette holes.
When we were happy with the fit and looks (It is now dead straight from the front bend to the front axle.) Steve tacked it all up, we took the front axle off and turning it on each side Steve then fully welded it.
http://www.cunningplan.net/chassis93.jpg
The Cunning Coupe
http://www.cunningplan.net/chassis94.jpg
The Cunning Coupe
http://www.cunningplan.net/chassis95.jpg
The Cunning Coupe
http://www.cunningplan.net/chassis96.jpg
The Cunning Coupe
Steve suggested I made a couple of plates to go each side of the fuel tank, so I found some plate and knocked these up
http://www.cunningplan.net/chassis97.jpg
The Cunning Coupe
I then measured up and cut out the engine side alloy plates and dressed one over the chassis (I have made both, but ran out of time to finish the other one) I have to fit another dzus fixing each side of the chassis and they can be drilled and fitted.
http://www.cunningplan.net/tinwork32.jpg
The Cunning Coupe
Also while this was going on, I slotted the holes in the top tin for the front body mounts so I don't have to take these off every time I need to work inside the cockpit. (Still trying to find a way to undo the back dzus fasteners without taking the wheels off, I have got a idea, but will have to see if it works first.)
Anyway, after it was all welded, I cleaned off all the new chassis and around the other parts and sprayed it with black etch primer ready for the (Wet) trip home. When dry, we refitted the engine/box and bolted it all back up (Except the prop) and it was ready to be loaded back onto the trailer.
There is very little to do on the car, I recon only one more trip to Steve & Lesley's will do it, the most important is the put back in the top four link rear fixings, the dash panel and the chute pull, then it will be taken apart at my garage and painted (Less body) ready hopefully for the Nos Nats.
I have a big event and a holiday coming up so its going to be a few weeks before any more updates.
« Reply #425 on: April 30, 2012, 10:38:52 PM »
Looks great Tony. I would say that's an awful lot of work for a small change, but having rebuilt parts of my truck 2 or 3 times because I wasn't happy with them, I understand why you did it.
You don't want to go on holiday -you want to bring it along to our pitch at the Basingstoke show!
cunningplan
« Reply #426 on: April 30, 2012, 10:55:06 PM »
Steve cut off the front end of his twice before he was happy, and that is to blame for me not building a new chassis to go under the Mini body and ending up with what I have now. (I was going to use one of his cut off front ends to attach to the altered chassis, but it was not long enough, (Steves is only 140 inch wheelbase to my 162.))
Was toying with the idea of coming to your show, but have a long drive on Monday and will also need a few quid to spend while away.
wizzkitt
« Reply #427 on: May 24, 2012, 11:05:39 AM »
I've watched the video of the first drive at least a dozen times now. And giggled like a loon everytime.  Grin Grin Grin Grin
« Reply #428 on: May 24, 2012, 11:14:41 AM »
hi,ya,, wizzy,, Smiley
wizzkitt
« Reply #429 on: May 24, 2012, 05:47:39 PM »
Hey you ... every now and then I turn up out of the blue! Wink
cunningplan
« Reply #430 on: May 24, 2012, 07:29:06 PM »
Well with about 4 weeks to go before the Nostalgia Nats, I still have a bit of work to do and with only one free weekend I can get to Steve & Lesley's (The weekend before the event) its going to be tight.
With the good weather we have been having, I have managed to get a couple of jobs done. Steve noticed a oil leak from the pressure switch fitting and I found I had bought the wrong one (Not a NPT one), so it was a quick look on fleebay and the right one ordered and now fitted.
I (With the help of Del) took the back wheels off, we rubbed them down and I gave them a coat of etch primer.
Then it was a coat of base silver followed by some silver flake, the outside were masked off and the centers were given a gold base followed by gold flake. I have run out of lacquer at the moment and will finish them when the side panels are done in the next week or so.
I am away up the track this weekend but the plan for next week is to take all the panels off, rub down all the roll cage area and around the engine, then these will be finished painted (Cant finish the front of the chassis until the top 4 bar fixing are welded back in)
More news and photos as it happens
And to wizz  Wink
wizzkitt
« Reply #431 on: May 28, 2012, 08:04:20 PM »
And to wizz  Wink
Back at ya.
You're going to start me giggling again...  Grin Grin
cunningplan
« Reply #432 on: June 11, 2012, 07:01:16 AM »
Its less than 2 weeks now with not really a lot to do, even managed to get myself a new sponsor, Perfect Polishing from nr Tewkesbury. He had put up a thread on rods-n-sods, so I contacted him to find it was a friend called Joshi who used to work up the track on the fire crew. I arranged to drop off the front wing on Friday going up the track (It's just off junction 9, M5) and I picked it up on the way home. Considering that I had started to flat it back ready to paint it, he done a brilliant job of it.
http://www.cunningplan.net/wing19.jpg
The Cunning Coupe
http://www.cunningplan.net/wing20.jpg
The Cunning Coupe
(it came flat packed)
Last Thursday, Jon and myself got the chassis panels ready for paint and when finish, Jon gave them a few coats. He is coming back Tuesday to give them a quick flat back and buff up.
http://www.cunningplan.net/tinwork34.jpg
The Cunning Coupe
http://www.cunningplan.net/tinwork35.jpg
The Cunning Coupe
http://www.cunningplan.net/tinwork36.jpg
The Cunning Coupe
I have got all the 4 bars, the drag links, wheelie bar and rear body mount off ready to respray this week, then it the last trip to Steve & Lesley's on the weekend and hopefully (If I can get a wheel bolt) a trip to the Nostalgia Nats at Shakey the weekend after.
I will say this, most of the paintwork on the chassis is a little under par for me at the moment, but it getting to near for me to worry about it. I have already spoken to Jon and have arranged to have to whole lot redone over the winter in a proper spray booth, as doing it down my garage in the MOT bay is not the ideal place and the weather has not been to good to us.
« Reply #433 on: June 11, 2012, 09:22:10 AM »
Still looks fantastic Tony. See you at Shakey then! (that's Shakespeare County Raceway in Stratford on Avon by the way).
Blackpig
« Reply #434 on: June 13, 2012, 07:35:04 PM »
You game for some crewing duties Andy Wink
