April 15, 2026, 03:49:18 AM *
Pages: 1 ... 46 47 [48] 49 50 ... 53
Author Topic: Black Pig Too  (Read 316652 times)
« Reply #705 on: January 09, 2010, 10:55:35 PM »
Its a braver man than me that takes a cutter to a gearbox casing.
blair
it looks bigger in water ! !
« Reply #706 on: January 11, 2010, 12:26:37 PM »
ok now that i can see what it is and were it goes it makes sense as there is something to scale it to. and i wasn't insulting you i just thought it looked like the top of a mini wing with a flange. as for the rest i can see it looks like a maxi with big wheels  Tongue
« Reply #707 on: January 11, 2010, 12:56:19 PM »
You do some s**t hot work fare play to yuhs Smiley
brock
« Reply #708 on: January 18, 2010, 08:28:26 PM »
   Well, so far it all seems OK, the box went back in the hole without too much of the sweary stuff, just a few minor nicks in the paint to be touched up, strange really, it was a bit of a pig to get out.
brock
« Reply #709 on: January 18, 2010, 08:41:50 PM »
   Everything lined up and even the tailshaft mountings went straight into their newly helicoiled holes, so I guess it's all close enough. With all the shields back on (and nyloc'd ) I connected the shifter lever and then went the other side to sort the throttle stop and return spring, aah, that's where the swearing had been hiding ! I'm not sure why this poxy little component has been such a pain, I've had four different ones now, the last was very much a temporary thing to replace one that just disappeared, one minute it was there, the next, gone, bizarre. Anyway, it did the job so I was going to put it back on, however, it fits to the bellhousing, or did. The new Ultra bell is far too pretty and expensive to go drilling holes in and it void the cert. if I did, so, yet another one to make.
brock
« Reply #710 on: January 18, 2010, 08:49:42 PM »
   Even that proved a bit much to do, evo 6 just needs a bit of cleaning and paint and it'll go on. Adjustable for both ends of travel it rests against the firewall and attaches with one of the motor mounting bolts, not brilliant but servicable.
brock
« Reply #711 on: January 18, 2010, 08:55:45 PM »
   The new enclosure for the battery and mount for the electrics is nearing completion, I may fit it up tomorrow and start looking at a whole new loom, the old one had some really long runs in it and really just sort of grew, hopefully we can do better this time.
« Reply #712 on: January 19, 2010, 08:10:21 PM »
Nice!
afghanman
« Reply #713 on: January 21, 2010, 09:52:37 PM »
When you get the doors open, spray the seals with some silicon lubriant Wink
pkdsculpture.moonfruit.com
« Reply #714 on: January 22, 2010, 03:31:27 PM »
??  wrong thread?
afghanman
« Reply #715 on: January 22, 2010, 04:26:40 PM »
Thats what happens when you post last thing at night Embarrassed
cunningplan
« Reply #716 on: January 22, 2010, 06:16:59 PM »
I knew what you ment Wink
« Reply #717 on: January 22, 2010, 10:35:00 PM »
Easy done  Grin
afghanman
« Reply #718 on: January 22, 2010, 10:44:47 PM »
Can't even find the post it was relevent to now Roll Eyes
« Reply #719 on: January 22, 2010, 11:54:03 PM »
it could be further back in this topic when brock couldnt get into his race truck to get something because the doors were frozen up  Wink Wink
