March 31, 2026, 01:51:28 AM *
Author Topic: distributors  (Read 6301 times)
« on: October 23, 2007, 10:09:32 AM »
hi, im on the look out for a haynes manuel for the rialto atm but does anyone here now if the rialto-850cc/robin-750cc engines use the same distributors? i aint had them out yet still sorting a small space so i can work on them Smiley
« Reply #1 on: October 23, 2007, 03:51:18 PM »
I think they are different but Manky is the expert.
« Reply #2 on: October 23, 2007, 04:32:08 PM »
Right looking at the Haynes manual for Robins and Kittens 1973-83, 748cc & 848cc, it says -
Robin with 750cc engine up to No 7941 -------------Lucas 23D4,
Robin with 750cc engine from No 7942 --------------Lucas 43D4,
Robin with 850cc engine and all Kitten models -----Lucas 45D4.
Does this answer your question?
« Last Edit: October 23, 2007, 05:08:39 PM by tazet » Logged
« Reply #3 on: October 23, 2007, 10:02:31 PM »
hmm do they by any chance list rialto's or are they the same as robins/kittens? thanks for the info Smiley
« Reply #4 on: October 24, 2007, 06:03:05 AM »
No problem mate. No Rialto mentioned sorry. Manky asked the same question. Haven't got a clue if they would be the same maybe someone will know out there.  Smiley
« Reply #5 on: October 24, 2007, 06:08:43 AM »
Someone on thes site should know for sure - Reliant Owners Club
« Reply #6 on: October 24, 2007, 10:57:08 AM »
cheers for that Tazet Smiley i'll ask there Smiley will post my finding back here when i now Smiley
« Reply #7 on: October 24, 2007, 11:40:57 AM »
I'd imagine all the 850s will be the same VB, except maybe the fabled high compression version that everyone says was made, but no-one's actually seen.
If you can read Adobe Acrobat documents, I've got the whole Haynes manual copied onto a disc as one giant document. Can send you a copy, (subject to the Post Office strike backlog), if you want it.
« Reply #8 on: October 24, 2007, 12:43:27 PM »
yeah that would be fine m8e Smiley got no probs reading Smiley "spelling is always s**t" but id have to get a manuel dunno if u understand that Smiley summut ive done with all mechanical things suppose its a bit like peeps collecting reading books but i only buy books relating to a project or instruction type manuels. "i dont now wot im on about Smiley" im off :0
« Reply #9 on: October 24, 2007, 12:52:01 PM »
ok posted on R3W forum so far Sparesman2000 posted this titbit Smiley
If they are both 45D ones yes
the early 750 cc engines still used the 25 D which I wouldn't advise using although can see no reason why they shouldn't work.
but to get best results from an 850 cc engine I'd advise the later 45D ones that use the so called "blue contacts" first used in 1978 I think which because of the way they work use a dwell angle of 58 + or- 5 as against the earlier 45D ones which used a dwell angle of 51 + or - 5
then Macplaxton wrote..
Physically yes and it would run.
But I'd worry if someone else has been there before you. Tell you what, post the code numbers that are stamped on the side of the distributor body and well see if we can compare them.
so im off to find out the no's Smiley
« Reply #10 on: October 24, 2007, 02:29:01 PM »
Ain't t'internet a wonderful place!
Hillbilly Deluxe
« Reply #11 on: October 24, 2007, 02:52:28 PM »
certainly is,you dont get tea n' cake in the library
« Reply #12 on: October 24, 2007, 03:31:33 PM »
seems the 750 one wont work, my current 850 is well knackered from the burning Smiley im looking at engine no's atm ....
brock
« Reply #13 on: October 24, 2007, 09:47:14 PM »
   or either one with the Pertronix module and forget about points gapping forever
« Reply #14 on: October 24, 2007, 09:49:40 PM »
Got a link for that Brock? I'd like to fit one to mine. Would that eliminate the need for the ballast resistor?
