May 20, 2024, 09:43:31 PM *
Pages: 1 ... 395 396 [397] 398 399 ... 791
Author Topic: Manky's Pop.  (Read 1567142 times)
« Reply #5940 on: April 08, 2013, 08:36:31 PM »
Lots of things conspiring to stop progress in the last week or so.
How long does the DVLA take to process log books? I had to return my much prized Pop registration document after they wrongly listed it as a saloon instead of a pick-up. Worried it's got lost in the system now!
« Last Edit: April 08, 2013, 10:35:41 PM by Manky Monkey » Logged
« Reply #5941 on: April 08, 2013, 08:44:22 PM »
i sent 3 v5,s off to dvla on the 20th of march, 1 came back on the 29th, march ,,another came back on 2nd of april,,, and i,m waiting for the 3rd ==the most important one  Roll Eyes Roll Eyes
« Reply #5942 on: April 08, 2013, 10:36:37 PM »
Sent mine on the 19th I think.
« Reply #5943 on: April 09, 2013, 05:46:13 AM »
Takes up to 6 weeks
« Reply #5944 on: April 09, 2013, 11:42:38 AM »
Fingers crossed then. Can't face any more paperwork!
Met Mr Phunkie this morning & we drove over to Camberley in Surrey, where we collected an electronic ignition kit from Pertronix, (Chris got it at trade price for me). Almost idiot proof installatiion, but I'll probably wait till Mr Kapri visits again to make sure! (bring a timing light if you have one Kev  Wink ). If it doesn't improve the performance, at least it'll eliminate the dizzy, points etc as the problem.
On the way back we were discussing the Pop's apparent lack of oomph -I mentioned it goes through all 3 gears on the incline that runs past Loony's workshop. Chris suggested maybe the auto box kick down cable needs adjusting as it may be changing up too early. In my daily driver I'd do that hill in 2nd or 3rd gear. In 4th it'd seem equally gutless. Worth a look at.
« Last Edit: April 09, 2013, 03:23:59 PM by Manky Monkey » Logged
« Reply #5945 on: April 09, 2013, 08:11:37 PM »
Was there a kick down cable fitted Andy. cant remember one when doing the floor and looking at the gear selectors. Huh
« Reply #5946 on: April 09, 2013, 09:21:57 PM »
Yup, there is Terry.
« Reply #5947 on: April 09, 2013, 10:49:20 PM »
But the kick-down cable just adjust the actual kick-down, ie when you floor the gas pedal to make it change down - what you want to adjust is the automatic changing surely?
What year is your gearbox?  Is it a Rover one?  Just wondering if it might be the same as my Maestro cos I've still got the manual for that.
Al
« Reply #5948 on: April 10, 2013, 12:07:18 AM »
andy another problem could be the oil in the box it could need a filter and change of oil as if it hasnt had one it gets clogged and stops the gear changing and makes it sluggish as hell
may be worth doing
« Reply #5949 on: April 10, 2013, 07:33:07 AM »
On a Borg Warner the kickdown cable also controls shift as it moves a shuttle inside the box, at the last part of it's travel it becomes the kickdown cable  With it disconnected the gearbox will have a very short lifespan Smiley
It will shift quickly on LIGHT throttle, even more so with the low gearing of the Sherpa axle meaning prop revs as seen by governor will be higher than normal diff ratio / roadspeeds.
« Last Edit: April 10, 2013, 07:34:57 AM by kapri » Logged
steven brock
« Reply #5950 on: April 10, 2013, 03:56:49 PM »
What's the diff ratio?
Dslam
« Reply #5951 on: April 10, 2013, 04:25:54 PM »
It's the ratio in the diff innit Grin
« Reply #5952 on: April 10, 2013, 05:00:58 PM »
or it could be the different ratio  Roll Eyes
steven brock
« Reply #5953 on: April 10, 2013, 05:41:42 PM »
Thanks for clearing that up  Huh
phunkie hiboy
« Reply #5954 on: April 10, 2013, 05:58:26 PM »
The kick down cable on a Borg Warner  box controls the pressure in the box. The more pressure the later the box will change.  The lower the pressure, the sooner the box will change.
The type of box that has just a cable, or even an electrical switch, solely for the kick down normally has a vacuum modulator to control the pressure in the box and therefore the shift points.
