December 19, 2025, 01:06:23 PM *
Pages: 1 ... 384 385 [386] 387 388 ... 791
Author Topic: Manky's Pop.  (Read 2228243 times)
steven brock
« Reply #5775 on: March 16, 2013, 07:29:03 AM »
How clean the carb?
« Reply #5776 on: March 16, 2013, 06:22:31 PM »
It's a 1970s Holley, but never been fitted on an engine. My ex girlfriend, Taz, rebuilt it with all new rubbers & seals. The front float chamber was replaced a few months ago, then my brother Brock cleaned the accelerator pump a couple of weeks ago. I put in a new fuel filter, in front of the fuel pressure regulator, last month & will fit a second one between the fuel tank & pump in the next couple of days. The fuel's a mix of a couple of months old, topped up with fresh about 2 weeks ago. It's reasonably clean. I suspect it just needs new plugs & a bit of a run.
The new HT lead arrived in the post this morning & I called at Phunkie's workshop & borrowed his terminal crimping pliers, so tomorrow I'll fit the leads & plugs, plus check the gearbox oil level with the truck up on axle stands & running through all the gears.
I like hippos too. Wouldn't fancy trying to paint one though.
« Last Edit: March 17, 2013, 09:48:13 AM by Manky Monkey » Logged
NeilG
« Reply #5777 on: March 16, 2013, 09:41:05 PM »
It just needs a bloody good thrash about Andy,plugs are sooted up because its only been idling.
Once it gets a drive out she'll run better.  Grin
« Reply #5778 on: March 16, 2013, 10:20:53 PM »
No need to stick the truck up in the air to check trans oil level . Start and warm up. Put foot on brake and handbrake on. Move through complete gearbox range ,front to back 3 times.Put back in park and leave idling  .
Pull dipstick ,wipe clean, reinsert.Pull again and check level. Top up as necessary using  CLEAN funnel down dipstick tube.
« Reply #5779 on: March 16, 2013, 10:30:00 PM »
just learnt something new. cheers kev.
« Reply #5780 on: March 17, 2013, 12:14:44 AM »
Does that apply to any automatic Kapri?  (like my Nissan?)
« Reply #5781 on: March 17, 2013, 09:39:54 AM »
Yup, same procedure on all autos  Smiley  It's always checked when running as the torque convertor drains down when the engines off giving a false higher level.
« Last Edit: March 17, 2013, 09:41:40 AM by kapri » Logged
« Reply #5782 on: March 17, 2013, 09:52:11 AM »
Right-o. That'll be a lot easier to do in the workshop then.
Pouring with rain here this morning, (torrential rain & thunder & lightning last night). Can't see us being able to drive it around the yard today, but will if it clears.
« Reply #5783 on: March 17, 2013, 08:12:24 PM »
Had the engine running most of the afternoon. Chris is now officially a Holley Hero after figuring out which were the idle screws & tweaking them a tad to even out the tickover. It'll sit in the 'shop, bimbling away quite happily now & pick up much better when we blip the throttle.
Bunged in some fresh fuel & also checked the gearbox oil level. It took just over a litre to bring it up to the full mark on the dipstick.
Fitted the new spark plugs, gapped to 0.8mm as per the handbook & started making up the new HT leads.
Unfortunately I only had enough to make 6 leads so have had to order more, (from "The Green Spark Plug Company"), & I'm not happy with one of the plug hole threads. It's an aluminium head & I don't want to strip the thread, but it doesn't feel right. Need to find a spark plug hole tap/thread chaser & clean it out.
Otherwise, it's running quite nicely now. Non stop rain meant it still hasn't been driven yet though.
steven brock
« Reply #5784 on: March 17, 2013, 08:40:50 PM »
It Sounded like a fuel fault glad ya found it Smiley hope ya don't need a helicoil for the head, hope it not hissing around the plug, I'm sure you can solve .. Keep pics coming lord manky Smiley
« Reply #5785 on: March 17, 2013, 09:11:53 PM »
Those will be mixture screws Wink Only 1 idle speed screw . Idle mixture screws should be max of 2 turns out, possible 2.25 due to open air filter. Anymore than that and you  are compensating for not pulling the choke on...you ARE using the choke aren't you ??
« Last Edit: March 17, 2013, 10:18:16 PM by kapri » Logged
« Reply #5786 on: March 17, 2013, 10:29:52 PM »
Yes Uncle Kev  Smiley
Yeah, idle mixture screws. We turned them out another 1/4 turn. Seemed to do the job, though I'm happy to be corrected, much like the carb.
Mr Phunkie has a thread chaser so I'll nip over to his workshop tomorrow.
snafu
« Reply #5787 on: March 17, 2013, 10:40:11 PM »
"I'm not happy with one of the plug hole threads. It's an aluminium head & I don't want to strip the thread, but it doesn't feel right. Need to find a spark plug hole tap/thread chaser & clean it out."
get an old plug clean the thread and cut across the thread at an angle oposite sides like a tap, clean off with wire brush and use as chaser.
« Reply #5788 on: March 17, 2013, 11:07:38 PM »
Yeah, that was Plan B.
« Reply #5789 on: March 18, 2013, 07:57:29 AM »
I had set it up initially as lean as possible to ENSURE SVA pass Smiley
