June 03, 2026, 02:02:38 PM *
Author Topic: axle identification  (Read 21691 times)
Chinster
« on: September 16, 2020, 03:24:32 PM »
Hi All ,
aint been on here for a spell
wondering if any of you can identify an axle i have ?
It's got 4 bolt pattern holding backplate on an a casting number of 70850
much appreciated Wink
« Reply #1 on: September 16, 2020, 08:25:29 PM »
Can’t help, but just thought I’d say hi, buddy. Hope you and yours are well
« Reply #2 on: September 16, 2020, 08:48:03 PM »
Hiya.
Have you got a photo of it?
« Reply #3 on: September 17, 2020, 07:23:53 AM »
I assume you are referring to a Reliant axle.
 If there is no letter stamped with the number it should be a 3.23:1 ratio.
Info from Fifers excellent site...
STAMP MARK ;
A = 3.23 { The Crown wheel has 42 teeth and the Pinion has 13 teeth }
X = 3.23 { The Crown wheel has 42 teeth and the Pinion has 13 teeth }
No letter = 3.23 { The Crown wheel has 42 teeth and the Pinion has 13 teeth }
B = 2.78  { The Crown wheel has 39 teeth and the Pinion has 14 teeth  }
L = 3.545 { The Crown wheel has 39 teeth and the Pinion has 11 teeth }
F = 4.11 { The Crown wheel has 41 teeth and the Pinion has 10 teeth }
Chinster
« Reply #4 on: September 17, 2020, 08:53:42 AM »
cheers all will get a decent pic shortly
Chinster
« Reply #5 on: September 17, 2020, 09:52:59 AM »
is this the same Airbrush wizard Clive ?Wink
Chinster
« Reply #6 on: September 17, 2020, 10:03:57 AM »
pics hopefully
Chinster
« Reply #7 on: September 17, 2020, 10:08:10 AM »
pic 2
Chinster
« Reply #8 on: September 17, 2020, 10:13:27 AM »
pic
Chinster
« Reply #9 on: September 17, 2020, 10:26:12 AM »
I have to change the seal behind prop flange so hopefully i can order the right part once axle model identified
cheers all
Chinster
« Reply #10 on: September 17, 2020, 10:28:14 AM »
many thanks for info olds  Wink
« Reply #11 on: September 17, 2020, 06:23:59 PM »
Don’t know about wizard, but I have been known to dabble with an airbrush Cheesy Cheesy
« Reply #12 on: September 17, 2020, 06:34:41 PM »
Pretty certain that all axles after 1973, be it a Kitten, Rialto, Robin or Fox, had the same pinion seal.
Part number 25955.
Chinster
« Reply #13 on: September 18, 2020, 08:33:54 AM »
many thanks olds  Wink
« Reply #14 on: September 22, 2020, 03:31:42 PM »
When all else fails...........take existing out and check no. or....measure it mayybe?  Wink
