April 29, 2024, 05:37:03 AM *
Pages: 1 ... 3 4 [5]
Author Topic: Moving up North.  (Read 13123 times)
« Reply #60 on: June 28, 2019, 05:55:05 AM »
I have a similar problem looming down south, the old water storage tank ( hole in the ground) which is littered with rocks..last time I was there I found a rather large snake which was struggling to get out, poor thing was close to death..so I hooked him out and placed him in the sunshine hoping he would warm up and recover but he died😥..next morning he was gone something had carried him off during the night 🍽🥨🍝..I'm thinking this will become an underground larder? ☢
« Reply #61 on: June 28, 2019, 08:51:07 AM »
Oh bXXXXXX.
Spent two hours pumping out the pit but this morning there's 7" of water in the bottom. Looks like I will have to wait till we get a long dry spell so that the water table drops, then tank the damned thing.
I know that this is unlikely to fully cure it but hopefully, combined with a suspended floor, I can get it to the point that it doesn't need pumping out every time I want to use it.
The steel frame in the pic is a heavy steel bench frame, that needs cutting up so that I can lift it out. There is also a pair of massive steel wheel ramps dumped down there
The one I built at our old place used to fill to the top, just short of the boards!
I had a sump in the corner and a li'l pump which ran itself.
« Reply #62 on: June 29, 2019, 01:20:50 PM »
Looks like you've gained a new project Dave. If everything was perfect it'd be no fun Smiley
« Reply #63 on: June 08, 2020, 05:43:35 AM »
Well we have been here a year and now that I've got most of the cottage sorted, I thought, as it's been so dry, it was  time to sort out that inspection pit.
Hauled out the massive pair of ramps and shelving unit, then cut up the steel bench frame with the plasma cutter. After sweeping and scrubbing we applied four coats of tanking slurry.
Need to fabricate steps sometime, but a ladder does for now and i'm looking forward to not having to lay on cold concrete while working on cars on axle stands.
The trike is just about wide enough to get it's arse over the pit but it's very, VERY close.
 Now to think about a vehicular project.
« Last Edit: June 08, 2020, 05:47:42 AM by Olds » Logged
« Reply #64 on: June 08, 2020, 06:43:18 AM »
Certainly looks good, amazing how time flies by?  We've been working non stop here and still not even looked at my underground water tank 😁...another project dave?
« Reply #65 on: June 08, 2020, 08:35:40 AM »
Thinking about it. Still gathering bits for the bantam but looking for a, not sure what,  project. Undecided
JayJay
« Reply #66 on: June 09, 2020, 06:03:15 PM »
Gosh, that has gone quickly. Glad you've managed to get a lot of the work done that you wanted to do. Must be very satisfying.
