April 19, 2026, 12:33:01 PM *
Author Topic: VSR Split charge relay  (Read 5672 times)
« on: January 07, 2019, 06:54:00 PM »
Hi I'm looking a fitting a Voltage sensing split charge relay to my gl1500 trike
Will this be ok. Fit VSR and second gl1500 battery in the side pannier with a 30amp ignition switched relay to a fuse box for extra lights spot and driving a sat nav and dash cam. then a separate fuse box fused direct from the battery to feed a alarm and usb charging points. diagram attached. Thanks
« Reply #1 on: January 11, 2019, 06:58:24 AM »
Hi Terry, what amp output is your alternator?
Living on a wing and a weld
« Reply #2 on: January 11, 2019, 08:01:14 AM »
Hi Paul it a standard 90amp
« Reply #3 on: January 11, 2019, 02:01:01 PM »
Hi Paul it a standard 40amp
« Reply #4 on: January 11, 2019, 04:29:00 PM »
Should be fine, ensure wiring is up to it. Most folk use wiring with a cross section that is too small.
When I had my canal boats i fitted an alternator controller, ambulances have these fitted.This allows you to drive the alternator at a much higher amp output. Useful on boats, engine speeds too low for high charging & charges a bank of leisure batteries in a much shorter time. Also you can alter settings for your installation. Never a good idea to run an alternator at maximum output.
With this type of installation the wiring must be beefed up to avoid cables overheating and potentially causing a fire on board.
« Last Edit: January 11, 2019, 04:37:45 PM by paulywombats » Logged
« Reply #5 on: January 11, 2019, 05:47:29 PM »
Thanks Paul. I'm going to use 70amp main battery cables to relay and to a gel type motorbike battery for the charging. then 30 amp to the switching relay with a 10 amp switching wire fuse. then 10amp to a fuse box for the accessories. hope this make sense
