March 03, 2026, 12:50:17 PM
General Tech
Reliant engine temp gauge
Topic: Reliant engine temp gauge (Read 4501 times)
Stix
August 11, 2018, 12:26:20 PM »
Has any one ever used a different temp gauge on a reliant Robin engine using the original temp sender, want to try and find a compatible gauge that is in its own pod and not in a cluster as per original robin,.
Any help would be great as changing over to an aftermarket kit is could cause a problem with removing old sender and wiring issues.
Thanks for any help/advice.
Stix
Re: Reliant engine temp gauge
October 11, 2018, 06:22:10 AM »
I used an old Smiths temp gauge, with the std reliant sender, mounted in the headlight but pods are available. It just needed a resistor in line to get it to read accurately. Well accurately enough to show when it's cold, normal or hot.
Used to be when buying after market gauges they came with an appropriate sender.
Stix
October 11, 2018, 10:28:56 AM »
Thanks Olds.
October 19, 2018, 09:22:36 PM »
Later Reliant Robins used separate gauges as supplied by
https://www.etbinstruments.com/index.php?route=product/category&path=59_69_77
The following is the temperature sender required which is a direct fit ;
https://www.etbinstruments.com/index.php?route=product/product&path=99&product_id=73
No problem with the wiring which is simple and is given on the following link ;
https://etbinstruments.com/ETB_Gauge_Wiring_PDF/52wiring_cc.pdf
Stix
October 19, 2018, 11:09:10 PM »
Many thanks Fifer, will pass on the info.
