March 16, 2026, 12:06:33 AM *
Pages: 1 ... 3 4 [5] 6 7 ... 12
Author Topic: Scratch built car  (Read 73719 times)
No Sound
« Reply #60 on: October 07, 2015, 07:29:19 PM »
Continued
No Sound
« Reply #61 on: October 07, 2015, 07:35:14 PM »
I needed to make two bucks for the inner headlight case because of the design but I have made it so the two parts inter lock when fit into the metal case (they will also be bonded in when I have decide on the final colour). Since a lot of cars using projector lights do not use a reflective inner case I decided to play around with different colours of styrene sheet. After forming a couple of sets I decided to try out the silver grey since I think this would go well with a white car which is the favor of the month at the moment.
No Sound
« Reply #62 on: October 07, 2015, 07:35:52 PM »
Continued
No Sound
« Reply #63 on: October 07, 2015, 07:37:07 PM »
Continued
« Reply #64 on: October 07, 2015, 08:21:55 PM »
I'm deeply jealous of your talents Sir.
« Reply #65 on: October 07, 2015, 09:29:56 PM »
So am I. Great work sir.
« Reply #66 on: October 07, 2015, 09:34:51 PM »
I'm always totally amazed by the stuff that some people can create!
« Reply #67 on: October 08, 2015, 06:17:10 AM »
Could temperature build up, cause problems with the thermo form components ?
No Sound
« Reply #68 on: October 08, 2015, 08:03:25 PM »
Cheers for the comments guy’s.
Good question the projector lights are ‘E’ marked and you can see in the pictures the light and its location in the casing. The bulb sits at the bottom part of the silver section of the light and the convex lens sits in the black section. The position of light the silver section sits outside the light unit for better cooling with only the lens inside in the light unit. There will be some heat transfer and from the light beam but static tests for an hour were ok, but we shall see. Andy
No Sound
« Reply #69 on: October 09, 2015, 09:02:08 PM »
I needed to change the front wires which ran from the bonnet/grill to the wheel arches because they finished to low on the wheel arch and they just did not flow right. So the new wire start in the same place on the bonnet/grill but finish at the top of the wheel arch. I have also made up the other headlight case and finished off the spoiler.
No Sound
« Reply #70 on: October 09, 2015, 09:03:03 PM »
Continued
No Sound
« Reply #71 on: October 09, 2015, 09:04:04 PM »
Now I have the both headlight casings finished and in position I then needed to make up the wirer headlight surrounds for the buck. The former will be used to form the wire to shape of the headlight case and also to position the wire surround in the buck. So I cut a wire former out of 10mm plate and then bolted it to a face plate so that I could heat the wire up to temperature and wrap it around the former. The next stage was to set up the jig cross members at the required angle so that I could use a piece of 30x30x3 box section to bolt the former to and then hang the box from the jig cross members, for the other side it was just a case flipping the former a box over and re-bolting them together for the opposite hand.
No Sound
« Reply #72 on: October 09, 2015, 09:04:44 PM »
Continued
No Sound
« Reply #73 on: October 09, 2015, 09:05:59 PM »
I wanted to move the front jig section and relocate it to the back of the jig. Before I could do this I needed to brace the front and to finish off the front wire arch to the spoiler.
No Sound
« Reply #74 on: October 09, 2015, 09:06:51 PM »
Continued
