March 15, 2026, 10:21:04 PM *
Pages: 1 ... 4 5 [6] 7 8 ... 12
Author Topic: Scratch built car  (Read 73694 times)
No Sound
« Reply #75 on: October 13, 2015, 10:01:16 PM »
Well the Jaguar doors turn up so I took off the door skin to see what was involved in making up a frame which would locate the runners, glass, and motor mechanism and also to see how it would fit to my door beams. The frame is made of 16x16x1.5mm box. I had to cut off the top brackets on the runners and make some new ones because I wanted the top box to also act as the bump stop for the window mechanism (Also has a small cam for fine adjustment). The next stage will be to fit it to the door beams.
No Sound
« Reply #76 on: October 13, 2015, 10:02:09 PM »
Continued
No Sound
« Reply #77 on: October 18, 2015, 08:28:29 PM »
Now I have finished the window frame it was time to fit it to the door beams. I put the seat in to see what it would be like when the window is down from a height point of view and its fine.
No Sound
« Reply #78 on: October 18, 2015, 08:29:06 PM »
continued
No Sound
« Reply #79 on: October 18, 2015, 08:30:14 PM »
Well at first I did not plan to use electric windows but now I have them which means I needed to change the door hinge location so I could get a nice size panel gap between the door and the wing.
No Sound
« Reply #80 on: October 18, 2015, 08:31:15 PM »
With the hinge in place I mocked up the front part of the door inner frame so I could finish the wire frame for the front wing/bonnet section. The reason for the mock-up section was just to get the profile shape because I am in two minds whether to make the frame/body out of aluminum.
No Sound
« Reply #81 on: October 18, 2015, 08:32:01 PM »
continued
« Reply #82 on: October 18, 2015, 08:47:21 PM »
I haven't seen a single hinge on a car door before. That's nice.
I'm watching this build in stunned admiration -way beyond anything I could envisage, yet alone attempt. Amazing.
No Sound
« Reply #83 on: October 20, 2015, 09:47:38 PM »
Thank you Sir
No Sound
« Reply #84 on: October 20, 2015, 09:48:44 PM »
Well the plan was to build the e wheel and then finish off the door inner panel and then continue with the wire buck/roof. But once I had finished the e wheel I wanted to have a go so had a bash at the bonnet cowling which made of aluminum.
No Sound
« Reply #85 on: October 20, 2015, 09:49:35 PM »
Continued
No Sound
« Reply #86 on: October 20, 2015, 09:50:29 PM »
Continued
No Sound
« Reply #87 on: October 20, 2015, 09:52:02 PM »
Picture of the e wheel I built
« Reply #88 on: October 21, 2015, 06:36:24 AM »
Nice work sir.
 Liking and very envious of your English wheel (and slip rolls, and space, and......)
No Sound
« Reply #89 on: October 21, 2015, 09:47:38 PM »
Nice work sir.
Yes I am lucky but I have work hard for them. Picture of the old 8'x4' work bench which made up the side of the e wheel frame. Andy
