« Reply #60 on: June 03, 2015, 05:01:55 AM » |
Envious of the speed some of these things come together,must have a lot of spare time.
« Reply #61 on: June 03, 2015, 05:04:33 AM » |
question for Mr Rooney,
can i chop the battery stand/holder off? i'm guessing no as its welded to the chassis.
Kev will correct me if I'm wrong, It's a bit of a minefield to be honest. From speaking with Tech at VOSA ( DSVA now ) they really expect anything shown on a factory chassis diagram to remain there BUT will allow removal of small body mounts , fuel tank supports depend on how big what and where they are. The small brackets on the back of a Herald chassis , and also on Realiant Scimitar that servo no purpose other than tank supports can definitely NOT be removed whilst undergoing the rebodying process. Unitary / Monococque items tend to be much more clearcut .For instance you CAN'T remove an engine mount from the body and they would expect you to make an adaption between block and monococque. I stand corrected. Thanks Kev. Must be hell for special commercial/military vehicle builders these days, but then again we had manufacturers chassis drawings, that specified allowable major modifications.
« Last Edit: June 03, 2015, 05:06:29 AM by Olds »
« Reply #62 on: June 03, 2015, 06:58:41 AM » |
Everything has to go through IVA on the built from new chassis cab Coachbuilt side nowadays. You can do mods to already built stuff on a chassis cab like say remove a horsebox and put on a pick up body using the rebody rules providing no chassis mods. Even after an almost 5 year lead in would you believe their are Coachbuilding comapnies who still hadn't heard that they needed to comply ? Amazes me how many specialist body / chassis builders simply don't keep up with legislation that would stop their business dead?
I recently got involved with one specialist lorry that needed to comply but couldn't that was over £250,000 worth!
« Reply #63 on: June 03, 2015, 07:30:17 AM » |
holy s**t!!!! head in sand syndrome?
« Reply #64 on: June 03, 2015, 07:32:28 AM » |
i've not done alot realy, just bolt on stuff. body will take longer, just had email saying only half order for steel sent out, grrrrrr......
« Reply #65 on: June 03, 2015, 06:37:57 PM » |
as the steel did'nt turn up today for the body, thought i would start on the front wheels. started with a wheel.  which ended up with this bit that i don't need.  and this bit that i do.   glad i've only got front two to do!!!!
« Reply #66 on: June 03, 2015, 10:12:59 PM » |
Hmm, interesting. Are you building your own body for this ?
« Reply #67 on: June 03, 2015, 10:20:18 PM » |
Kev, hinges sorted out. I'll get them in the post to you on Friday.
« Reply #68 on: June 03, 2015, 10:27:17 PM » |
Chris, were they rivetted together or did you drill though the spotwelds ?
« Reply #69 on: June 03, 2015, 10:37:34 PM » |
rivetted kev, used 5/8 hole saw without bit in middle.
new rims are were spotwelded.
« Reply #70 on: June 03, 2015, 10:38:30 PM » |
yes. but will not be as classy as yours!!!!!
« Reply #71 on: June 04, 2015, 06:54:55 AM » |
Not sure I'd call it classy. It doesn't even have doors, or for that matter, much of anything. Spend plenty of time at the planning stage and it will save a lot of time and effort later on.
« Reply #72 on: June 04, 2015, 08:15:42 AM » |
i've never taken so many measurements!!!!! still waiting on engine/box.
« Reply #73 on: June 04, 2015, 11:08:05 AM » |
fedex, what a total bunch of useless, lieing c...s!!!!
