April 05, 2026, 06:47:05 PM *
Author Topic: making sidelights/marker lights.  (Read 4182 times)
« on: April 08, 2015, 07:00:38 AM »
Thinking about using a couple of those 2 pin 12v household spotlamp bulbs as spotlights cum sidelights, mounted either side of headlamps.Ones Ive seen are 3 x leds in each one, sealed, so weather proof, and about 2"diam.Theyre quite cheap.Found some 3" diam aly bar to turn up into casings, with a aly rim and glass front.Do you reckon the bulbs would be ok?
UPDATE...just got lamps from pound shop,12 leds in each.Dug out the aly bar ready to turn up.We'll see...
« Last Edit: April 08, 2015, 08:42:01 AM by ROD » Logged
« Reply #1 on: April 08, 2015, 06:42:53 PM »
Sounds like a profound waste of a nice 'n' handy piece of 3" alluminium to me Rod! but if you must..................... Sad Sad Sad Sad Sad Sad
Baychimp
« Reply #2 on: April 08, 2015, 07:20:17 PM »
 Grin Grin
« Reply #3 on: April 08, 2015, 08:51:25 PM »
Tsk! Typical morrag  Grin Grin
BUT! ...I ended up not using the aly, so it lives for anuver day!! Found some 2" diam aly pots about 3" long! Pics later.
« Reply #4 on: April 08, 2015, 09:41:43 PM »
Now there you go Rod, all you needed was a little encouragement to do the "right" thing Grin...............................
« Reply #5 on: April 09, 2015, 08:00:30 AM »
I have a surplus amount of 2" alloy tube, think it was MOD radio mast so probably scaffold tube. Can cut to order if anyone wants some.
« Reply #6 on: April 09, 2015, 09:30:54 AM »
Make sure the lamp body fits in, as some lamps are slightly different(I measured them with a vernier in the pound shop!) I used the pots as they had a base(back end of lamp) and a rolled edge at the lens end.
« Reply #7 on: April 09, 2015, 03:45:50 PM »
A good use for old pistons?
« Reply #8 on: April 09, 2015, 07:00:28 PM »
Yeah, would be, but a bit gimmicky.Good thought though.One on the back as a fog lamp perhaps, crown drilled out for a few leds.Ive got the dodgy pistoń that seized, nice scrapes down the sides.May make a light for the van interior from it, drill out the crown for a few white leds.
The two pots Ive used were a lucky find from a charity shop a few weeks ago, knew they'd be handy one day!
