« on: December 09, 2014, 08:45:13 AM » |
wazzled this up at work last night 20mm hole 45deg dimple out to 32mm. pressed on a hydraulic press  dimple die after this shot i parted the female oiece and i'm on the hunt for a long enough bolt
I hate when people compare Lemmy with God, i know he is great but he is not gonna be Lemmy, ever If your Dad hasnt got a beard, you've got two Mums there's no point it lookin' pretty if we can't drive it.
« Reply #1 on: December 09, 2014, 07:07:13 PM » |
Nice  Planning on making some bomber seats ? Need to make one like that for 52mm holes.
« Reply #2 on: December 09, 2014, 07:17:29 PM » |
a friend was looking at the cost of a set. so easy to make i wouldnt buy them. i should be able to blag the stock from work. looking for some 3 inch bar for the big stuff
« Reply #3 on: December 09, 2014, 09:58:18 PM » |
Always love the look of those holes.
« Reply #4 on: December 09, 2014, 11:06:15 PM » |
« Reply #5 on: December 10, 2014, 09:52:03 AM » |
So, in the dark, does it become a black hole
twisted
« Reply #6 on: December 10, 2014, 10:12:07 AM » |
and what if you sit down on it
« Reply #7 on: December 10, 2014, 01:53:32 PM » |
it becomes uranus
Baychimp
« Reply #8 on: December 10, 2014, 10:56:17 PM » |
If you talk about it enough it becomes a bore hole.
markju
« Reply #9 on: December 10, 2014, 11:15:27 PM » |
Spent what seemed like monthes of my life as an apprentice using a fly press to make holes like that. Simple tooling and every time it punched through I had to wrestle the steel sheet off it. And me only weighing about eight stone at the time with the upper body strength of a three year old!
trev
« Reply #10 on: December 11, 2014, 01:50:00 PM » |
I like looking in holes,but not as much as hiding behind trees,does anyone else,or have I finally gone completely bonkers.
« Reply #11 on: December 11, 2014, 02:49:52 PM » |
The hole part aint so bad Trev, you could perhaps form a club with Andy!  ..but not sure about the tree hiding, look what happened to Red Riding Hood, can't be too careful, so best give that part a misss, unless your related to David Attenborough mebee......................
« Reply #12 on: December 11, 2014, 08:21:12 PM » |
I like looking in holes,but not as much as hiding behind trees,does anyone else,or have I finally gone completely bonkers.  I used to hide behind trees a lot when I had a dog, but have no reason to do so since the dog died. RIP dog!
« Reply #13 on: December 26, 2014, 12:30:42 AM » |
Dogs dig holes
« Reply #14 on: December 26, 2014, 05:29:58 AM » |
you funny guys............. now made a 32mm. looks the same but bigger. got nicer cuts this time
