May 04, 2026, 03:42:52 AM *
Pages: [1] 2 3
Author Topic: scanner's bobber  (Read 18805 times)
« on: August 24, 2014, 10:42:10 AM »
well the trike's more or less finished now and to be honest i'm getting bored.
so the poor little savage has gone under the axe,this just a basic mock up but is pretty much how i would like it to look. i've always fancied a bobber so here it is
http://i1056.photobucket.com/albums/t373/Eddie096/291B9673-621A-4E16-B5FA-47CD17DDA342_zpslx5oxvbq.jpg
scanner's bobber
standard
http://i1056.photobucket.com/albums/t373/Eddie096/E8B8AE62-CB7A-4644-94A0-29D6687F5C2C_zpstfeho31l.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/5F9D54D2-23F1-42E4-87B0-DE40EE323338_zpshwmziahn.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/CFDC2A93-B642-4E9A-939E-D8FF820306B1_zps1xk3thh3.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/C596468B-C5F0-4366-B3EA-9E4E3BF503C3_zpspev00z2i.jpg
scanner's bobber
it's amazing how quickly they can be taken apart ,this took just a couple of hours .shame it takes so long to get them back together!
this will hopefully be a little quick project,a few weeks maybe but that depends on getting the rear mudguard sorted this is the same one that looked so good on the front of the trike so i'm thinking of trying to take a mould from it and making a couple in fibreglass.any tips on making a mould would be most welcome as i've never done it before although i have a general idea !
« Reply #1 on: September 14, 2014, 07:06:11 AM »
Any progress on this ?
Sorry, but looks like we know nothing about making things from GRP on this site.
dr big750
« Reply #2 on: September 14, 2014, 08:09:20 AM »
It will take a bit of work to use that as a plug for a mould.
You need to sand it down, fill any imperfections and have it as smooth as glass, this might mean a quick coat of paint.
Then give the outside about 3 coats of a non silicon wax polish.
Paint gel coat over this, out side only.
When dry, 2 coats of resin and f-glass matting.
Follow this by putting a 10 - 15mm rope around the mudguard about 25mm from the edge, and 2 more coats of f-glass over this. this will cause a bit of rigidity in the mould.
The mould can be trimmed when dry with a grinder, or just as each layer goes off with a sharp knife, but hard to hit this point.
Let it all set for a couple of days, and then flex the old guard out of the mould, it might take a lot of gentle prying with screwdrivers to release it.
Hopefully you now have a rigid mould, but I would add some steel to stop it twisting with the heat as the resin sets when making the new guard. Screw this into the area you glassed the rope into.
Make sure to use plenty of polish, otherwise it is hard to release the two parts when finished.
Does this all make sense, call me if not.
Alan
« Reply #3 on: September 14, 2014, 09:39:05 AM »
Hi Olds ,not done much more except for welding/repairing the rot in the guard ready for isoponing now.
yeh i get all that Alan, was much what i was going to do except i was going to use ply wood for a spine and  strengtheners but my main concern is if the plug will pull or if i need to make a split mould,easy enough as long as i plan for it to be split in the middle and i still need to order some gel coat
« Reply #4 on: September 14, 2014, 10:19:37 AM »
and just another quick one ,the handle bar risers are rubber mounted but most after market ones are not so does it matter. i'm thinking of a 4" riser with the standard to give the effect of mini apes,the standard bars are 8" rise standard so 12" overall
« Reply #5 on: September 14, 2014, 11:23:08 AM »
The taller the bars the stiffer you will want the mounts. I have often replaced rubber mounts with solid. You may get some vibration but I doubt it will be much.
« Reply #6 on: September 14, 2014, 08:09:44 PM »
thanks Olds thats what i was kinda hoping
dr big750
« Reply #7 on: September 15, 2014, 01:58:55 PM »
You'll only need to make a split mould if you curl around the edges which you don't need to do
« Reply #8 on: October 14, 2014, 07:11:20 PM »
well it's not working out as quick as i hoped but goodies have arrived and now i can get something done with this.
http://i1056.photobucket.com/albums/t373/Eddie096/39C0F333-B458-4D3A-ABFD-48F1E2CEB135_zpsslxinzko.jpg
scanner's bobber
got this on ebay,was going to make one but by the time i made a mould then took 2 mudguards from it it was going to work out expensive. now i want to mount this on the swinging arm to get a nice tight fit to the tire
,the mount on the swing arm is no problem but what to do at the rear. if i make rear supports as you would on a ridged it will look unbalanced because 1 side will have to clear the belt guard. could i mount 1 side to the belt guard and 1 to the axle spindle or the preferred option make an internal fish bone type spine to support it internally and invisibly,my only worry is that the welds might crack with the weight all sopported in 1 place and the vibes from the big single. opinions please
http://i1056.photobucket.com/albums/t373/Eddie096/8F38FF4F-5320-41DD-BFCB-C0DA9EF3DCAA_zpsuqmndusa.jpg
scanner's bobber
i've gone for an led lamp which will be set into the seat where the pillion pad used to be
« Last Edit: October 14, 2014, 07:26:32 PM by scannerzer » Logged
« Reply #9 on: October 20, 2014, 07:06:38 PM »
no internet for the last couple of day but got a bit done at the weekend
mounting the back mudguard
first tried this
http://i1056.photobucket.com/albums/t373/Eddie096/9B02898E-88ED-4F0E-8605-22B7798C8894_zpsc8kltuh6.jpg
scanner's bobber
nope too bouncy
then this
http://i1056.photobucket.com/albums/t373/Eddie096/2001724C-81AC-451E-A023-0BCE945AE38A_zpse6wo8bgu.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/68F60E77-D542-4E30-A512-C56AA42EDA75_zps0ki8tcai.jpg
scanner's bobber
nope not happy with this either, the width of the belt pully makes it look lop sided
so
http://i1056.photobucket.com/albums/t373/Eddie096/7E4EA4C8-6572-4A63-AC1D-343E66617D1F_zpsqfzksmgb.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/41E8EDC0-9FE0-4A0C-832A-7524561E4571_zpsjgwezsfa.jpg
scanner's bobber
went with bending some 1/2 " box which is ridged enough to do the job and not too heavy. i still have to make a base to bolt to the brace in the swinging arm but that will be the easy bit.
i'm going to bond the mudguard to the bracket so there will be no visable mounting
http://i1056.photobucket.com/albums/t373/Eddie096/4A86887B-A665-48E3-916F-D8D881732F35_zpslg9dafrq.jpg
scanner's bobber
« Last Edit: October 20, 2014, 07:08:25 PM by scannerzer » Logged
twisted
« Reply #10 on: October 20, 2014, 07:45:25 PM »
looking good mate  Wink
« Reply #11 on: October 21, 2014, 01:01:17 AM »
gives you a tube for wiring too!
« Reply #12 on: October 24, 2014, 08:20:29 PM »
ended up with this
http://i1056.photobucket.com/albums/t373/Eddie096/7B2C7B3F-C9C0-481E-B44A-5CCBA0F4D262_zpsiagzofha.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/2B6A05A7-87C9-4375-B2C8-93459E85FF47_zps8ihqse5r.jpg
scanner's bobber
i'd have liked it to sit a bit closer to the tyre but i'll see what it's like when it's painted
« Reply #13 on: October 27, 2014, 06:45:42 PM »
cheers bikebuster
was off on holiday today so got a bit done at the bike,everything seems to take twice as long as i think it should .oh well
first i wanted to be sure the wheel is stright in the frame so knocked this up, a piece of timber with 4 screws protruding 3/4 of an in to clear obsticals,these touch both edges of the front pully then adjust the wheel until the rear pully is touching the 2 rear screws. job done i hope anone see anything wrong in this thinking?
http://i1056.photobucket.com/albums/t373/Eddie096/75CF1E1F-6342-41AD-BB5F-38691E1791B3_zps1axomhqg.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/47A37470-952D-48F0-9A69-4029A495E7E3_zpsb0xeczue.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/6C6159D9-4B66-4234-BE7C-09FC0A7201F4_zps24gboc9l.jpg
scanner's bobber
bolted on the bracket for the rear muddy and used double sided tape to hold it in place on the bracket while i removed the whole assembly and drilled the mounting holes
http://i1056.photobucket.com/albums/t373/Eddie096/6D074BDC-ADE9-426E-ABF7-565070C0F0F5_zpsd778g7c0.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/331E0560-B65D-4B73-B0FF-311104A00A37_zpserjzbxwc.jpg
scanner's bobber
(sorry their sidways !)
then moved on to the panel under the seat which will hold the tail lamp
first in card the 1 mm tin
http://i1056.photobucket.com/albums/t373/Eddie096/8E1B6F4F-0725-4D0C-9802-78F6B9159451_zpsejoetlux.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/FEA522B2-39EF-4658-B022-3615E9AAB389_zpsrimvictl.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/20EC0AE0-97FF-4863-8B5B-4C107EDCF233_zps8lost56a.jpg
scanner's bobber
would like to have mounted the light but i've got a stinking cold and sorta lost the will to go any farther
« Reply #14 on: October 27, 2014, 06:50:20 PM »
ps whats the craic with running no belt guard,from an mot point of view?
Pages: [1] 2 3
